was there ever trans am door decal like iroc decal?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
hey guys i think i have seen them before but can anyone clarify if trans ams ever had door lettering decals?
i have seen one on a junk yard car but was on the ground effects under the door
i think it would look good on the door in black letters and at the bottom be like the iroc decal with lines going through it
and if there was is there anyone selling it now?
anyone?
im pretty sure i have seen it on the early 82-84 models where it had a few layers of pin stripes going thin to thick from top to bottom on the lower edge of the car all the way around
and trans am would be spelt within those lines on the door
just never saw it again just in a picture i saw years ago
and i would like it for my car
anyone?
Re: was there ever trans am door decal like iroc decal?
thats correct. the 1984 trans am 15th anniversary editions had that decal. the cars were white with blue decals. you can buy the decal kit from phoenix graphix. http://www.phoenixgraphix.com/transam/8415th.htm
![](http://www.phoenixgraphix.com/transam/c8415th2.jpg)
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
WOW never seen those. Learn something new every day. Im done for the day at 9:46 lol.
Axle/Gears: no idea
ok thanks, i want to see if i can get those in black thanks guys
Engine: 355 TPI
Yea email phoenix graffics and ask. Im sure they could do it but it might cost extra since they never came that way from the factory.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The 91-92 Trans Am had some largeish "Trans Am" decals on the door on the ground f.x.
one thing I will tell you, make sure it is in the correct font for the year. If you just pick some lame font and have it cut out in vinyl they look like crap.
![my 2 cents](https://www.thirdgen.org/forums/images/smilies/twocents.gif)
John
John
Axle/Gears: no idea
no one would know of the actual font would they?
I am assuming that it is the 1986 TA... If i remember I will send it to you tomorrow.
John
John
Axle/Gears: no idea
thanks i like the style 82-84 trans am lettering if u saw my car its not an 86 anymore haha bolted on 82-84 body style
Here,
I believe this was the correct lettering for 1982 - 1986 Trans Am's
I have the original in CorelDRAW! so you can have it vinyl cut.
John
John
Axle/Gears: no idea
hey thanks
that is awesome
what do you mean i can have it vinyl cut?
like take the file to a graphics decal/vinyl cutter to make the logo for me?
that is awesome
Axle/Gears: no idea
sorry i have no idea what coreldraw is haha
is it some kind of graphic design program like CAD or what>?
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
yes it is a graphic design program but I don't think you need it to save the file. I would say you should be able to save it, print it out take it to a graphics maker etc. then they should be able to replicate it. Am I right John?
Axle/Gears: no idea
ok thanks,
is that good enough quality or can john send me the coreldraw document?
http://www.phoenixgraphix.com/transam/1984ta.htm
I am going to order the whole thing when I get to that point; so you might want to call and see what they mean by names can be ordered separately.
Axle/Gears: no idea
i already have the decals for the fenders and bumpers
i want that photo above that has the trans am logo from the 15th anniversary trans am in big letters on the door
i can ask phoenix grpahics to make it in black
but they are alittle pricey
if i can get the image document id like to see if i can find a better deal locally first
I would take the font and the photo to the local vinyl decal shop and have them put two and two together to make it. Shouldn't be too hard for them to do with todays technology. Good Luck with it. It would look great on those cars if done right. I am sure you are planning on doing that anyway.
Axle/Gears: no idea
yes i wana buy from phoenix graphics the 82-84 lower decals which r just thinner to thicker lines that go aroudn the car above the groudn effects and make that trans am door logo
basically what the 15th asnniversary has but in black on my metalic gray car with black ground effects
Axle/Gears: no idea
here i took johns jpg and made a logo with the lines through it. i dont have the demensions so i tried to eye ball where the lines are based on the photo way above
CorelDRAW! is a Vector program, more like a combination between CAD and a photo editing program. The only other popular program that I can think of is Adobe Illustrator. They both do the same thing. Many Vinyl shops like CorelDraw because it is easier to use and less expensive...
If you go to a sign shop, ask them if they will make you a couple of decals, if I sent you the file all you have to do is give it to them on disk. They should make it on any type & color of vinyl you want.
John
John
Of course the easiest thing you could do is just get it from Phoenix.
John
John
Axle/Gears: no idea
thanks john, yea and but im not sure if phoenix does custom requests. ill call and ask
but im wondering if the cheaper way for the same result is someone local
ill compare both and see
Axle/Gears: no idea
I just called and purchased the door logos from the 15th anniversary kit in black from phoenix graphics
20 dollar custom request charge since they offered it only in blue and i requested black
also purchased 1984 lower stripes molding in black
6 stripes going around the lower part the car above the ground effects
the stripes go from thin to thick from top to bottom.
i'll post pictures in a month or so once the decals come in and i have time to apply them
thanks guys
thanks guys
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
mustangman65_79
08-11-2015 03:17 PM
