Super Rare Hood!?!?
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Super Rare Hood!?!?
I found a fiberglass hood, on a iron duke camaro. It has the correct small louver indents, but at the rear of the indent it has a flap like a ram air that opens and allows air into the engine bay. On the underside of the hood, it has a mechanical linkage that opens and closes the flap. Is this really rare and worth buying? Thanks alot.
Car: 87 GTA
Re: Super Rare Hood!?!?
Not really "rare", but those hoods were only on 82-84 Zs. SOME 85s too, I believe. Or was it 82-85? I forget.
Car: 89 IROC-Z
Thanks for the fast reply. I know the fiberglass hoods are somewhat common, but i never seen one with this ram air flap and linkage. So have you seen this type of ram air hood?
1 Post
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i thought it was the crossfire cars that got those hoods? and i also thought they stopped makin it for the 84 year cuz of rain getting in the engine bay, so im thinkin 82-83? not 100% on those facts and im a bit tired lol. btw my 84 z had no flaps or holes.
Car: 87 GTA
I've seen a couple of those "flap" hoods, but I think both of them were "broken". As in, the flaps were no longer functional. You could open them by hand, but the auto mechanism no longer worked on either one.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Those hoods are found on '82-83 z28 with the Lu-5
crossfire injection engine,originaly there was an electric
solenoid to open the flaps that was triggered by the ecm.
Car: 89 IROC-Z
Thanks alot guys! So it kind of sounds like it would be a good hood to buy then? Now that i think of it i believe there was some wires running to it. But the car was an iron duke, not a crossfire. Hmmm
Car: 89 IROC-Z
makes sense, the rest of the car was shot lol. The guy wanted a hundred bucks for it, good deal if its in nice shape?
1 Post
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Yea i heard they only used the factory fiberglass hoods on 82-83 camaros (not sure which modles) but discontinued them in 84 because they were prone to cracking.
Car: 91 Camaro RS
mmmmm wouldnt mind have one of these hoods...
I've seen only one camaro with a flap that opens was my friend's 85 tan camaro. surpisingly his still works as much as I've heard they quit working easly.
I've been looking for one of these hoods.
Car: '86 Iroc-z
Engine: 385 stroker, vortecs, demon 750
Transmission: G-Force T-5
Axle/Gears: 9-bolt, 3.27s
I remember reading something where they discontinued these hoods early b/c of water leaks causing damage
Car: 1983 z28 camaro
Engine: 305 - LU5 bottom end.
Axle/Gears: 2.93 stock :-(
Car: 1983 Camaro Z28
Engine: 350 CFI
Transmission: 700R4 automatic
Axle/Gears: 3.08?
Mine works great yet. The hood is probably the nicest thing ON my car, hahaha!
Engine: 350 CFI
Axle/Gears: 3.08?
1 Post
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I found one of these hoods with working flaps in a trash pile at a wrecking yard....it was in perfect shape minus paint, and the flapper worked....I already had a hood on my car....so I sold it locally for $100 bucks.....should I have charged more???
[QUOTE=derekterbeest;4113438]sorry for the bird crap on the hood. i just got it out of winter storage. here's some pics
QUOTE]
That's great! Thanks.
I can see how it could be adapted to a carbed application using a traditional cowl induction air cleaner assembly. Hood clearence with a RPM Air Gap manifold is the only glitch. I'll have to investigate.
QUOTE]
Hotrodboba400
12-10-2019 07:07 PM
