Matching # Engines
Old 02-09-2009 | 10:41 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Matching # Engines
Where do I look to see if my engine is the matching # engine for my car. Will the # have some part of the vin. I know mine is the original engine in my car but I would just like to know that it is.
Old 02-09-2009 | 11:13 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Re: Matching # Engines
I was wondering the same thing. I still have the original block which I kept and took photos of the stampings I found on it when I pulled my L69 because it was blown. I just looked over the photos and while they are fuzzy I don't see anything that shows numbers matching except for something that says 5.0LG on the back I am guessing the G matches my engine VIN code. My heads were so trashed that I scrapped them but I kept the block for the numbers matching reason and I am hoping to have it rebuilt from the block I have for that reason. I've gotta get it out of the weather if i want to do that. At least my brother painted it so it may not be a lost cause.
Old 02-09-2009 | 11:31 PM
Pyroviking's Avatar
The castings should all have the last 6 of your VIN stamped on them.
Old 02-09-2009 | 11:35 PM
L695speed's Avatar
hmm maybe i better look at the block again. Where would it be?
Old 02-09-2009 | 11:39 PM
jermdm's Avatar
Car: 1989 Iroc-z
I wouldnt think that it would be the # on the rear of the block since that is casted into the block itself, but what about the #'s stamped on the head surface of the block(I think its on the pass. side head surface in the front next to the timing cover). I always remember a stamped # sequence being there on other engines I've rebuilt.
Old 02-09-2009 | 11:43 PM
L695speed's Avatar
Hmm... now that I think about it maybe there is something there. I will need to take a look at it over spring break. The heads are long gone but if I rebuild it to L69 specs from the block I should be in good shape for a numbers matching car if I can get that engine rebuilt. Worse comes to worse I will just put in a rebuilt L69 from another car and it will be correct because mine is a L69/T-5 combo from the factory. I have the PHS documents to prove it. (at least what they gave me)
Old 02-10-2009 | 10:48 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
jermdm has it right...
The stamping is under (behind) the alternator (1982-1987) or behind the Ac compressor (1988 - 1992).
Here is an example of a long gone 1987 Trans Am or GTA
The small numbers are what you are looking for 2HN211943
2 = Pontiac
H = Model Year (like VIN)
N = Norwood, L = Van Nuys (like VIN)
2 = Pontiac
11943 = Sequence number
John
Old 02-10-2009 | 11:51 AM
L695speed's Avatar
2 = Pontiac
2 = Pontiac
John
I went back through the photos I have of it and while it is really fuzzy; I have a photo like this. I was looking at the larger numbers and didn't notice the smaller ones due to the crappy nature of the photo. I can barely make out my sequence number and it matches. Maybe I should get the motor out of the back yard when I get home.......or should I say the block and whats left.....
Old 02-10-2009 | 02:05 PM
jermdm's Avatar
Car: 1989 Iroc-z
Thanks okfoz. Thats what I was wanting to know.
Azrael91966669
25
06-20-2017 04:04 AM
Reddeath210
10-06-2015 08:20 AM
bradleydeanuhl
08-12-2015 11:48 AM
matthew911
08-12-2015 09:38 AM
Elliswon
08-10-2015 12:33 PM
Quick Reply: Matching # Engines
