1985 Camaro rear end?
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
what goes in the two holes on the driver side front of this 85 IROC rear end.
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: 1985 Camaro rear end?
The torque arm. It connects to the back end of the transmission and keeps the rear axle level since there are only lower control arms. You're going to need one if its missing. Its a major part of the rear suspension.
Can I find one on any 3rd gen or is a Z28 thing?
Any 3rd-gen will have it but there are two different types. Base and lower end suspension levels used a solid torque arm while the WS6 and other high level suspensions had lightening holes in them.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
I can get you some pics but its going to be a couple months before I can take them. My '82 and good '84 T/A are both level III WS6 cars and have the torque arm with the holes in them. My '84 T/A parts car has the standard level II Y99 suspension and has a solid torque arm. I think as time progressed and lower lever suspensions were upgraded to the previous model years higher level suspension eventually all 3rd-gens got the torque arm with the lightening holes.
Not true... My 1992 Firebird V6 automatic has a solid torque arm. I've seen the ones with the holes in them (my 1984 15th anniversary TAs) and the one on the 1992 V6 isn't the same.
hectre13
12-11-2023 08:14 AM
AkDrifted
08-17-2015 07:45 PM
1984, 1985, 3rd, 85, axle, camaro, differential, end, gen, id, rear, suspension, suspention, type, z28
