My new 89 GTA w/factory CD player
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: My new 89 GTA w/factory CD player
Looks good, How is the paint everywhere else? Id say it was worth it. Mileage is pretty good also for a driver. Have fun with her. Put in a cam and an aftermarket intake if 5000 RPM is no fun... Thats what I did.
1 Post
Car: 89 GTA
Axle/Gears: 3.27:1 9 bolt
The paint is spiderwebbed on the nose right in the center, but otherwise good. A cam and intake are on my list, along with a bunch of other mods but I'm going to try to fix what's broken first. I see in your sig you have a fiberglass spoiler, mind if I ask where you got it? How do you like it? What's the cost on something like that?
1 Post
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Nice find!!! and yes, that "plastic coupling" is your MAF. Have fun with it, that is the first factory CD player I've ever seen in a 3rd gen.
Car: 88 Trans Am
Engine: 5.7 TPI
I'll trade you a brand new up to date current in dash CD/mp3 player for your old factory one.
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
I was told once that there were only about 110 1989 Firebirds built with factory CD players but I don't know if that's true. I hope it is because I've got two of them. Both of mine came from '89 Formulas.
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
You're lucky getting a factory player. Yours is the only other F-body I've seen with one.. As mentioned, check your RPO list for U1A.....
I wanted a factory CD player for my 90 GTA to keep it all stock. I hunted for 8 years looking for one in reasonable shape for a decent price. I managed to pick one up at a local wrecker a few years ago. I think I paid $150 for it.
1 Post
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
do you live in warrensburg? reason i ask is i see a white GTA with t tops exactly like that every time i go to my friend's house...he has an 88 GTA that we have been fixing up that will soon be mine.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
To answer one of your questions about the power lumbar on the drivers side, what does it do? If it runs for a split second and then shuts off you probably have a kink in your lines. If the pump runs without adjusting something then you might have a hole in a line or the bag OR something may be simply pulled apart.
How it works is actually BOTH front seats run off the same pump under your drivers seat, when you push a button there is a valve that opens and then it pushes or pulls air into and out of the air bags that are in the seat calling for air. There are some lines that go under the carpet & under the center console. I found that on my car when I installed the seats that I had to make sure the lines were not kinked when the seat backs were in the upright position... Lean the seat forward and see if it works.
as for CD players 2597 Camaros and 1095 Firebird in 1989... I actually have one for my 1989 Formula 350 Vert
John
John
Car: 92 purple haze z03 z28
Engine: Lb9
Transmission: 5 speed
Wow you got a good deal on yout gta. The cd player is rare on 89 f body cars. I bought my gta with 80,000 miles a few months ago and is just like yours except for the cd player. Does your car have dual cat. converters on it. Mine has them and I have owned a blk and tan gta with dual converters on it, I was surprised to find another one when I bought mine.
2012sergen11
10-13-2015 07:38 PM
