87 camaro iroc. limited edition badge around locks in both doors? not a convertable.
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
so ive been searching and cant seem to find anything on 87 irocs that were limited edition except the convertables. and their badge was on the dash.
my 87 iroc has limited edition badges surrounding the locks on each door.
they are white with silver cursive writing and look to be original and factory by age. and quality.
sorry this is the best pick i have kinda shows where and how its placed
![Name: IMG_0273.jpg
Size: 120.5 KB](https://www.thirdgen.org/forums/attachments/history-originality/440512d1501528380-87-camaro-iroc-limited-img_0273.jpg)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
Re: 87 camaro iroc. limited edition badge around locks in both doors? not a convertab
Those are aftermarket pieces. They were pretty common back then and were probably put on shortly after the car was new. If you look around you'll see quite a few cars with them but they never came from the factory that way.
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
funny enough i saw the same thing today on a salvage yard camaro and the same thing came over my head
Car: 89 Iroc
Engine: 5.7 TPI
thanks, thats a perfect answer. now any tips on how to get it off. haha.
its cracked and looks like poo. imo at least.
That could be tough depending on how long they've been on there because it may mess up your paint when you take them off. Also, there's a possibily you may still be able to see where it was at because of paint fade. There are special products out there made for removing old stickers, etc. You could also try using something like GooGone along with a razor. A heat gun may also help you out.
Car: 89 Iroc
Engine: 5.7 TPI
thanks, yea well the car needs paint any ways. but maybe ill wait untill the time im going to paint it to rip emm off that way i dont have to be so miticulas. thanks again
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
You could try heating the badges with a hair dryer or very, VERY carefully with a heat gun. The heat with soften the adhesive, then gently pry free starting in a corner. Once it's off, use some GooGone to remove any remaining adhesive residue.
1992 Trans Am
05-10-2023 07:19 PM
