Rear hatch glass replacement w/ rear defogger
1 Post
Car: 92 Z-28
Transmission: THM700R4
My glass is good, it is just my defogger that does not work. I wonder if anyone knows how to fix this except to replace the glass w/ a defogger in it?
1 Post
Car: 92 Z-28
Re: Rear hatch glass replacement w/ rear defogger
Thanks for the quick reply defarris. Have you ever used one of these repair kits or know or heard how well they work. 1 or 2 of my lines work so I know it is getting power.
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
that's strange that only 1 or 2 lines work. Do you know if someone went at it with a scraper trying to remove tint or something?
Car: 1986 Cevrolet Camaro Z28 TPI
Engine: 305 v-8 TPI
Transmission: Stock
Axle/Gears: Stock
I have a 1986 Z28 (TPI) and my rear defogger needs to be replaced. I have maybe a third of the lines broken/scraped/whatever off. I bought the car used so I have no clue who or how the defogger was damaged but the little repair kit from the store isn't going to be enough. The question I have is..... Would buying replacement defogger strips and scraping the old stuff off work? I am planning on removing what's left of the old strips and putting new ones on top of where the old ones were so my window doesn't look like crap with a hundred lines across it. When the strips are scraped off there is a thin brown line underneath where the strip was. Will placing new defogger strips on the old lines cause any issues?
Engine: 305 v-8 TPI
Transmission: Stock
Axle/Gears: Stock
Oops......won't let me delete....
Those kits are pretty hokey. For a small repair they're probably fine, but if you're working with a hatch that had tint film ripped off, the defroster is usually so destroyed that using the tiny kit will take forever.
I messed with the kit a few years ago, it was a waste of time and money. Maybe if it was a much LARGER quantity and you could tape off the entire grid and spray the entire grid it'd work, but with the supplied brush it'd take forever and only work marginally.
Get a hatch from a junkyard with a good defroster grid.
1 Post
Car: 1984 Trans Am
Warning- this is an old thread from 2008 that has inexpicably risen from the dead.
Street Lethal
04-30-2019 12:14 PM
