how many 91 L98 Z28's
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: how many 91 L98 Z28's
Also if the car has Factory T-tops it was not a L98 Car... So if you see a Factory T-top 90 - 92 Camaro it does NOT have the L98...
John
John
I am curious, what makes you think it was a BS reply... I was pointing out that there were no L98 Camaros after 1989 that had Factory T-tops... I was not trying to BS anyone, its a FACT, and if you do not like it then you can go away. Considering he has an LS1 in his car currently I am assuming that he is looking at another car. Besides you added that there was 9,990 LB9's actually there was 9,996.
John
John
Car: 1987 Black IROC-Z (SOLD)
John
John
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Again, check your facts. A 91 L98 Z28 could not be had with factory ttops. If you check the RPO codes, you won't find L98 and CC1 on the SPID. I guess we have proven that DJP has no idea what he's talking about. AGAIN!
Your answer can be found here: https://www.thirdgen.org/forums/hist...re-asking.html
If the link does not work you can find it at the top of hte History board
John
John
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
