84 z28 ????
84 z28 ????
ok so my friend is dead set that my car is a fake z28.
He claims because it doesn't have rear discs its a fake were-as I checked the vin at it is a real Z apperently.He claims there diff vins and not the orriginal.
And his moms bf thinks its a fake cause it isnt full posi but that lsd style.
Also believes my interior is out of a older 3rd gen because 84's apperently didnt have the camaro style interior for the z28....
Enyway doesn't enyone have a pic of a sheetlist so I can see for myself.
pics to come
pics to come
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: strange s60 4th gen width - 3.73
Re: 84 z28 ????
gonna need to see some pics. and you might tell your mom's bf that "full posi" might be a spool and nothing comes factory with a spool. and lsd stands for limited slip differential and gm's posi-trac is a limited slip differential.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 84 z28 ????
Tens of thousands of 1984 Z28s came without rear disc brakes, mine included
Nowhere in the VIN does it indicate that a car is a Z28. The VIN can only prove that a car can't be a Z28, if it shows anything other than a V8.
Posi and limited slip are the same thing by different names.
What's a "camaro style interior"? A Z28 is a Camaro, and had a Camaro interior.
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: 84 z28 ????
If the 5th digit in the vin is a P,then it should be a sport coupe or a Z28.Thats if the vin is correct.S= berlinetta.The code was changed in 1987 to P,for all camaros.
Alicat.
Alicat.
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
Re: 84 z28 ????
If its an l69 then its definately a z28. That would be a G for your 8th digit. Just because its not there doesn't mean that its not real. They came with lg4 engines too. Also check for the z28 rpo code.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: 84 z28 ????
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
1 Post
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: 84 z28 ????
84's i think still had the Trim Tag above the radiator. The 1983's did. If it is a Z28 built in Norwood, it would be on the Trim Tag.
https://www.thirdgen.org/forums/atta...t-id-plate.jpg
Re: 84 z28 ????
I know its a real Z28.
The vin is correct and my cowl tag is still there indeed.
But hes basing himself on the rear disc.Good to know only a rare few came disc and no where near all of them.
His moms bf claims its a fake cause its not a posi ??? wen the PO i know didn't pu tthe posi additif ( wich i should do tommorow at work indeed,or the clutch packs are done ).
He also said my interior ( the one printed camaro all over it ) was out of a nother car wen ive seen 84's with the same int.
I showed him my tags he claims they swapped them :laugh:
allright thanks.I gotta get some pics for you guys thanks for your help.
Its also my first domestic car I've been into vw's for most of my young life so sorry for the newbness.
Axle/Gears: 3.08
Re: 84 z28 ????
Here's a a couple pages right from the '84 Camaro sales brochure. In it are pics of the CAMARO, CAMARO, CAMARO interior.
http://www.camarosource.ca/new_site/...roch_page3.jpg
http://www.camarosource.ca/new_site/...roch_page6.jpg
http://www.camarosource.ca/new_site/...roch_page7.jpg
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Axle/Gears: 3.08
Re: 84 z28 ????
Also regarding the POSI (limited slip as defined by Chevrolet RPO G80) . . .
Number of Z28's in 1984 . . . 100,899
Total Camaros with RPO G80 in 1984 . . . 17,837
Again, the number of '84 z28's that had limited slip was very few.
PS; tell your friends they owe you a case of beer EACH!!!
Engine: L69 305 H.O.
Re: 84 z28 ????
Car: 1992 Camaro RS
Engine: 305 TBI
Re: 84 z28 ????
haha its funny when people act like they know what there talkin about and there wrong,just like my sisters friends calling my rs a iroc
its a 92 they didnt make irocs in 92 lol
![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
blackz281le
01-11-2016 07:51 AM
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
