Iroc Door decal color
Car: 1985 Camaro Iroc-Z
Engine: 5.0 TPI
Axle/Gears: 2.73 posi
I have a yellow 1985 Iroc-Z that's been repainted, and the door decals are gone. Is there an RPO code to determine the color of the IROC decals? The Z28 emblems on the lower front rockers are sliver, and the rims have gray metallic painted insets. I'm assuming the decals would be silver?
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Iroc Door decal color
I would almost think black, silver seems like it would be hard to see on yellow. Theres a picture of a yellow 85 on this page, and the door decals look black:
http://www.iroczone.com/techartspottersguide.html
However, a quick google turned up this, and they look silver:
http://toronto.craigslist.ca/tor/car/587659291.html
Edit: came across this page, it lists silver as the correct color (scroll down to IROC):
http://www.camarosource.ca/php/camar...trim&year=1985
This isn't at all the end all to this discussion, but it's been my observation that the door decal color is the same as the painted wheel inserts.
Unless the wheels have been swapped, etc., etc......
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
I would think there is a RPO code for it. . . might wanna try and decipher your RPO codes in your center console.
Car: '84 Z28
Engine: L69
Look on your RPO label, you should find code 86A. This was the silver/black stripe code for the '85-'87 IROC. The door decals were silver also.
Dang, that's poor English but you get the drift.
Engine: 5.0 TPI
Thanks for the input, I'll check for that RPO code... I had a friend come by my shop where I'm working on the car, he said "that's no Iroc". Really. I told him it's absolutely an Iroc-Z!!! Had to spout off the 'B4Z' code to him... he's a F**d guy and didn't understand! I do know that code.
1992 Trans Am
05-10-2023 07:19 PM
LT1Formula
08-20-2015 09:36 PM
mustangman65_79
08-11-2015 03:17 PM
