rear end ratio's for our cars
1 Post
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
probably a stupid history question about our cars, but its been bugging me. what rear end ratio do our cars have. they vary by engine, and probably transmission. but, does anyone have a link to finding out rear end ratios?
![help](https://www.thirdgen.org/forums/images/smilies/help.gif)
Car: rs convertible,06 dmax,07 tahoeltz
Engine: l03
Axle/Gears: 3:42 auburn posi unit
Re: rear end ratio's for our cars
Look in the specs at the bottom of the page it tell specs by each year of car
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
The only stock rear-end available for an '89 RS with a 2.8L is 3.42 (regardless if it's an auto or std).
For all the possible engine, model, drivetrain rear-ends offered, check out (as tweeker mentioned) the Camaro/Firebird Tech Data on our home page or the links at the bottom of this page. Select a year and scroll down.
The only stupid question is one that's not asked.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Several things drove the axel ratio of a car:
1) Engine & Transmission
2) Body Type, IE a Formula or GTA with an LB9 & M5 ALL would have gotten the performance gear, THe trans Am or IROC would have had the axel as an OPTION. The L98 Usually had the 3.27 or 3.23 ratio pretty much standard on Firebirds, Camaros I think it might have been an option some years.
John
John
hectre13
12-11-2023 08:14 AM
AkDrifted
08-17-2015 07:45 PM
1992 Trans Am
08-08-2015 08:16 PM
