Build Date?
Old 10-08-2007 | 09:47 AM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Build Date?
Does anyone know how I can find the build date of my car? I've heard it would be on the build sheet, but I've found the build sheet and there was not a date on it. At least, I guess its the build sheet. I found it behind the passenger door panel when I was changing the window motor. My scanner is busted, so I can't post a picture of it.
Anyway, I was putting a new stereo in the car the other night, and on the quality control stickers, and manufacture date stickers. One said June, 1992; the other said July 1992. My car must be a pretty late build, I'm guessing. When did GM stop producing third gens?
dave
Old 10-08-2007 | 01:58 PM
LeonardS's Avatar
Re: Build Date?
August 27, 1992 was the last date of production for the Third Gens.
Leonard
Old 10-08-2007 | 06:10 PM
Big Dave's Avatar
Re: Build Date?
Take a look at this. This is what I found behind the passenger door panel while replacing the window motor. It literally just fell out onto the ground when I removed the bottom clips. Apparently I was the first person to remove that door panel
Anyhow, I was expecting it to have a build date, but unless its a code or something, I ain't seeing it. Should I be on the lookout for something else when I re-do the interior this winter?
Old 10-14-2007 | 11:00 PM
David M's Avatar
Car: '84 Z28
Engine: L69
Re: Build Date?
Need the last six digits of the VIN to determine the build date.
Can be narrowed down to the exact day.
Old 10-15-2007 | 07:39 AM
Big Dave's Avatar
Re: Build Date?
The last six digits are 158148
Old 10-15-2007 | 09:07 AM
LeonardS's Avatar
Re: Build Date?
My calculations would say that 11,859 Camaro's were built after yours in 1992.
Leonard
Old 10-15-2007 | 06:08 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Build Date?
Mine is a 85 Iroc. The last six digits are 151486. Can you tell me if this would have been built in 84 or 85?
Old 10-15-2007 | 11:31 PM
RPM WOT L 98's Avatar
Re: Build Date?
Really? How can you do that? What source do you have? I'd be interested in finding out mine if possible.
Mark
Old 10-22-2007 | 06:58 PM
David M's Avatar
Car: '84 Z28
Engine: L69
Re: Build Date?
Big Dave, build date on your car is June 24, 1992.
Old 01-31-2008 | 03:01 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Build Date?
how in the heck do you figure the day from the sequential unit number ?
you have a book that lists what cars were built in each day ?
567676 in 1982
firebird
van nuys
what day was mine built ?
i already know it was 5th week of august 1982
08E
probably the 31st day right ?
thanks
Old 02-01-2008 | 11:34 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Build Date?
What would be the exact build date of my car. It is an 85 Iroc from the norwood ohio plant and the last six digits are 151486.
Old 02-07-2008 | 07:23 PM
frankwi's Avatar
Car: 90 Camaro RS
Re: Build Date?
I would really like to know the birth date for my Camaro.
Van Nuys 1990 RS
last 6 : 107898
I found a panel that had 9/14/89 written in chalk. I know ALL 90 Camaros were built in 89.
Thanks, Frank in Fort Worth
Old 02-08-2008 | 04:05 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Build Date?
567676 in 1982
firebird
van nuys
08E
thanks
I too would be interested in finding out where you get your information. I have a monthly production for 82-92 but by no means a Daily production...
John
Old 02-10-2008 | 11:24 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
Re: Build Date?
John
that was how i tracked down my two previous cars, and another local guy's car.
always wondered if there was a way to figure out which exact date....
Old 02-10-2008 | 12:12 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Build Date?
How does this apply to convertibles? Mine was converted by ASC in mid 1990. The sequence number in the VIN from the GM Van Nuys plant is 241480 and it was delivered back to Pontiac (not a dealer) after the conversion. Can you tell the date it was produced as the pre-conversion car by this number? Thanks.
Old 02-10-2008 | 02:03 PM
frankwi's Avatar
Car: 90 Camaro RS
Re: Build Date?
Nothing heard from David M since October last year, I think we are talking to ourselves here...
Old 02-11-2008 | 09:35 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Build Date?
David works for a dealer parts department if I remember correctly. He doesn't show up much but is still around from time to time.
Old 02-12-2008 | 12:27 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Re: Build Date?
John
the body tag under the hood, usually on the rad support
two numbers and a letter, together
by itself,
all you can get off it though is the month and week
what is your code ?
its simple to convert it to month and week
but for the day i dont know how other than buildsheet or something else
everyone has the month and week on their body tag
if i searched for a while i could find a thread of mine from in the past where i learned about this, and from who here i learned it from
because i have forgotten who
it will be in the history and resto board
why are you guys so bent on knowing what day anyways ?
whats the big deal ?
blame GM for not keeping records for us
good luck!
Old 02-12-2008 | 12:51 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Re: Build Date?
here we go.
Jeff is who showed me:
clicky here to see
Old 02-12-2008 | 01:13 AM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
Re: Build Date?
On 82-84 cars, if you can find the build sheet it will have a date at the bottom of box 1. This is the schedule build date. However, keep in mind that it’s not exact. A car can start on one day and roll off the line the next day. There can also be production delays and other thing and can throw the days off. So you can get close but it may not be 100% accurate all the time.
Old 02-12-2008 | 01:24 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Re: Build Date?
yeah
my buildsheet was already missing, someone already had the car interior apart at one point in the past probably when they repainted the car, so all i have is the body tag, and vin plate and thats it
i will never know what RPO codes it was built with unfortunately
some ppl are lucky and find an 82 83 build sheet and others arent
ppl are really good about finding and then losing important papers, and thereby screwing over future owners
but in my case i dont really care much since mine is just another late in the year regular LG4/200c equipped trans am WS7 that they sold billions of, and that needs new rear quarters, and a fender, and other repairs that cause it to not be worth much and only really good as a beater DD
almost any other 82 83 84 is/would be more interesting/lower production
ZEEYAA
04-16-2023 09:29 PM
MoJoe
Members Camaros
31
10-06-2021 07:38 PM
Jlanz55
09-29-2015 09:55 AM
F-body-fan
09-24-2015 09:29 AM
Thirdgen89GTA
09-12-2015 09:39 PM
