Camaro Question After 1990
Old 08-28-2007 | 08:07 AM
Genesis98's Avatar
Car: 88 Camaro SC
Engine: 2.8 ->305->350
After 1990 were all IROC parts (minus hood louvers) transfered to the z28?
Old 08-28-2007 | 11:50 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Camaro Question After 1990
Z28 was a mandatory part of an IROC from '88 to mid '90 when the contract expired.'85-'87 you had Z28 as a separate option on the Sport Coupe then B4Z was an option on it.Then in mid '90 the Z28 ID was used once again.Everything would have transferred,standard and optional equipment,with trim and color changes since the Z28s were actually a '91 model.I hope i'm explaing this correctly.
Old 08-28-2007 | 12:59 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Really after 1990 the cars cosmetically changed, the ground effects were all different, the hood was different, obviously the spoiler was different on the 91-92 Z28 than the earlier camaro.
As far as the suspension pieces I am not sure if the Wonderbar was installed on the 91-92 years.
John
Old 08-28-2007 | 01:02 PM
Genesis98's Avatar
Car: 88 Camaro SC
My fault for not specifying, aside from visual differences, did the suspension in 90-92 z28's change from that of the 88-90 Irocs.
Old 08-29-2007 | 03:47 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I believe 91-92 didn't have wonderbar?dont qoute me on that though
Old 08-30-2007 | 01:29 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, the 91-92 Z28's did not come with a wonderbar.
Yes the suspensions were different on the 91-92 Z28s. The IROCs had Bilstein shocks, the Z28's had Decarbon shocks. The spring rate was slightly stiffer on IROCs, too.
Old 08-30-2007 | 04:04 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Go IROC-Z's! Although, it has been rumored that some early cars recieved the wonderbar as left over parts.
Old 08-30-2007 | 08:24 PM
L69norm's Avatar
Didn't 91/92 use that special glue in the body seams in addition to spot welds so it was supposed to be a lot stiffer? Maybe it didn't need the wonderbar?
Old 08-30-2007 | 09:15 PM
Administrator
They used that stuff, but it didn't make much difference. I've still seen low mileage 91 and 92's with the stress crack over the top of the window on non-T-Top cars.
Old 08-31-2007 | 09:10 AM
okfoz's Avatar
It was discovered in Aviation 50+ years ago that sharp corners are a BAD thing. I want to think that it was the DeHavilland Commet that killed many people due to sharp corner construction in the window area.
SO 40 years later GM did not think that the sharp corner would matter? Honestly if I ever own a 3rd gen hard top car which I intend to drive I will be installing the reinforcement brackets in the door jamb that were used on the verts & T-top cars.
I have seen V6 cars with the stress crack, one guy said it was there after hitting a Rail road track hard.
John
Old 09-03-2007 | 10:55 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
I have a 1991 vert and it has a wonder bar. could have been put on by a previous owner, could be factory, maybe on verts only, i dunno. but it's there.
Old 09-04-2007 | 01:02 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
really.. I can't say I can recall seeing any extra reinforcement brackets in my t-top car vs. my current hard top. do you have a pic or anything? I'm very curious, thanks.
Old 09-05-2007 | 10:59 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
are you 100% positive that decarbon shocks were on 91-92s??
I know they came on 93 F-bodies and thought that was the first year.
The 5.0 TPI Z28 came with 235/55/16 as standard equipment in 91-92
Old 09-05-2007 | 11:06 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Some 91's(probably L98s) did have a wonderbar,mine being one of them.
Frozer!!!
01-19-2024 04:55 PM
84z96L31vortec
08-20-2017 12:16 AM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
redmaroz
08-16-2015 11:40 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: Camaro Question After 1990
