25th Anniversary emblem
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
I'm not sure if this is the correct place to ask this. Does anyone know or can you measure the distance from the edge of the hatch for the placement of the 25th Anniversary emblem. Mine was taken off at the body shop and wasn't measured. Just want it to go back in the correct spot. Thanks.
Car: 1992 RS Heritage
Transmission: TCI 700r4
Re: 25th Anniversary emblem
I can measure mine when I get home. Its an RS... I think the location would be different for a Z28.
Engine: 350 HSR
anyone? Looks like I can guess pretty good when the tail lights are in. Just double checking.
Car: Pair of 92 Z28s
Ok this is right from my 1992 Chevy Camaro Service Manual:
RS: From the tip of the spoiler its exactly 3mm or .12" down to the front of the emblem. 2.2" (55mm) to the right from the corner of the hatch.
It appears for Z28s it was 2.4" (62mm) over from the corner of the hatch.
Engine: 350 HSR
2012sergen11
10-13-2015 07:38 PM
