Are these 16" TA Rims Restorable?
Car: 1986 trans am, 1985 TRANS AM WS6
Engine: 305 4bbl,305 TPI
Transmission: 700r4,700R4
Axle/Gears: STOCK POSI DISC
There are a couple if gouges in the Aluminum on a couple of them,and some curb rash/bend on the front pass.side rim.I wanna sandblast them,and tun them into silver(POLISHED ALUMINIM) with black cutout slots.Any opinions if its worth the extensive time to try to save these rims? I cant afford to buy another set,and i OWN these at least.Any ideas in dressing those Gouges/rash? 1st 2 pics passenger side 3&4 are driver side.
THANKS!!!!
THANKS!!!!
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Re: Are these 16" TA Rims Restorable?
if you get them blasted do not use sand. I had some rims sandblasted and it makes the aluminum too rough and pitted. Have them use glass beads, or silica.
Car: '91 RS
Engine: 5.0L gross *** tbi
anything is restorable...it just depends on how much time/effort/money you wanna spend
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
ACTUALLY, blasing is the worst thing, you have to turn them on a lathe to get the correct pattern. Then repaint them...
ANYTHING is restorable, if you want to spend the energy, time and money.
Contact hitman@78ta.com he does 2nd gen restorations and when I was talking to him a few years ago he was eventually get into 3rd gens as well, but they were too cheep right now to do it right. He does wheel restorations for 2nd gens I do not know why he could not do yours.
John
John
John
John
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
Check out this tech article I wrote awhile back.
http://www.firebirdnation.com/forums...howtopic=12115
Of interest, they are the same wheels as the ones you're working on.
I hope this helps!
Leon
I hope this helps!
Leon
I hope this helps!
Leon
I hope this helps!
Leon
How about the PONTIAC lettering also...Paint the whole rim Black first and Then start your process?
By the way, you do BEAUTIFUL work!
Actually, the inner parts are painted a dark charcoal metallic, and yes it is a autobody paint and clearcoat.
If I were to do your wheels, I would start be using a strong liquid paint stripper, then after all the paint was gone, I'd sand the wheels smooth, polish them, and then mask of the polished areas, and spray the color on the inner parts of the spokes.
I used a brush and painted in the PONTIAC letters on the one spoke, and it turned out fine for me.
And thank you for the compliments, its always nice to see that other appreciate the hard work I put into my cars.
Good luck, and don't be afraid to ask for anymore advice..
Leon
Leon
Any body shop should be able to send those out to get restored. I offer it through my father's body shop, but generally because of shipping costs, it's cheaper for people to do it through their local body shop. Expect to pay about $200-225 per wheel, but what you get back will be a like new wheel front and back.
From the factory you can see how they originally painted the wheels
1) cast the rim
2) paint the charcoal color
3) Machine off the face to silver
4) clear coat.
Its not necessarily the easiest way for the shadetree mechanic, but it might give some ideas.
John
Leon,
Those wheels are Absoluetly gorgeous... The only thing personally I would try to do would resore the original machined look on the wheel.
What I have considered is to take an Industrial sewing machine motor, hook it up to a foot pedal control, and then to a (non posi) axel I have sitting in the back. Then I would anchor the other end so that only one wheel would spin. Hook the motor up to the axel (where the driveshaft would mount) Then make a tri-pod so that I could sit on a chair or stand up and have a regular tool for refinishing wheels.
John
1) cast the rim
4) clear coat.
John
Leon,
John
My father in-law has a full "old school" arsenal of machine shop/lathe equipment.He fabricates some pretty intense stuff.Im going to ask him to help me out with restoring these rims. Any idea what the EXACT paint code is for the charcoal grey paint guys?
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
