HELP PLEASE(pictures inside)
Today I traded my Recaro seats with a 3rd gen Camaro with no engine and tranny,the owner claims that the car is American spec and its 88 model I toke off the glove box and went to my room to check the RPOs,here's what i found about the car
AC3 : ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9 : ADJUSTER, SEAT, POWER, 6 WAY
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
A01 : WINDOW, TINTED, ALL SHADED, W/S
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BS1 : INSULATION, ACOUSTICAL PKG
BY1 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR 3
B18 : ORNAMENTATION, INTR, DELUX
B48 : TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C95 : LAMP, INTR, ROOF, COURTESY AND DUAL READING
DG8 : MIRROR 0/S, LH REM CONT, RH DIRECT CONT, BREAKAWAY,
DX4 : STRIPE, 2 SIDE
D02 : PAINT, ENAMEL MASTER
D27 : COVER, RR COMPT, TRUNK STOW
D34 : MIRROR, VISOR VANITY
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
GU4 : AXLE REAR, 3.08 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
KC4 : COOLING SYSTEM, ENG OIL
K64 : GENERATOR, 78 AMP
LG4 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
NM5 : EMISSION SYSTEM, CANADIAN REOUIREMENTS
NM8 : LEADED FUEL SYSTEM,
N33 : STEERING COLUMN, TILT TYPE
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
TR9 : LAMP, GROUP
T63 : ALARM, HEADLAMPS ON WARNING SYSTEM
T84 : HEADLAMPS, RH RULE OF ROAD, E MARK RECTANGULAR
T89 : LAMP, TAIL & STOP, EXPORT
UA1 : BATTERY, HEAVY DUTY
UE8 : CLOCK, ELECTRIC, DIGITAL
UL2 : FREQUENCIES, EUROPEAN RADIO
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
U03 : HORN, NOISE REGULATION
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 : LAMP, INTR, RR COMPT, COURTESY
U26 : LAMP, INTR, ENG COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U75 : ANTENNA, POWER, RADIO
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VT7 : PROVISION OPTIONS, UNREGULATED COUNTRIES
V08 : COOLING SYSTEM, HEAVY WTY
V78 : VEHICLE STATEMENT DELETE
YE3 : CONVENIENCE PKG, DECOR LEVEL #3, HIGH TRIM
YR2 : SEAT FRT, CUSTOM
YS2 : REAR SEAT, DELUXE
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
1AZ : Order Modification, Orders Sold (or: CUSTOMER ORDERED VEHICLE)
15L : SECONDARY COLOR, EXTERIOR, ASTRAL SILVER (91)
15U : PRIMARY COLOR, EXTERIOR ASTRAL SILVER (91)
16P : WHEEL COLOR, BRT WHITE (91)
82C : TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
86A : STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
here are some pictures of diffrent views that I didnt recognize this Camaro model
so what model is my camaro? It got weird big ugly turn signals and got a weird 3rd brake with 85 and 86 shifter,Please help I will give you the RPO's and tell me what model is this
AC3 AG9 AR9 AU3 A01 A31 A90 BS1 BY1 B18 B48 B97 CD4 C49 C60
C95 DG8 DX4 D02 D27 D34 D6J EXP E5Z E7Z E9Z FA1 FA2 GA1 GA2
GU4 G80 J65 KC4 K64 LG4 MD8 MX0 NK3 NM5 NM8 N0D N33 N65 N90
QYZ TR9 T63 T84 T89 UA1 UE8 UL2 UM6 UP8 U03 U21 U25 U26 U29
U75 U79 VC5 VT7 V08 V78 V95 YE3 YR2 YS2 YT9 ZK3 1AA 1AZ 15L
15U 16P 6KR 7KR 8PJ 82C 821 829 86A 9PJ
here is the chassis number
1G1FP87H1FN117106
Please guys help me
TR9 : LAMP, GROUP
1G1FP87H1FN117106
Please guys help me
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: HELP PLEASE(pictures inside)
The 10th digit of the vin is telling me the car is an 85, not an 88. If it was an 88 it would be a J. The H in the 8th spot tells us the car is a carbed 305. I don't see a z28 in the rpo package, so it's possible it just may be a heavily optioned base model.
Cheers!!!
Cheers!!!
Cheers!!!
Cheers!!!
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
I found a Camaro VIN decoder HERE and punched in your VIN.. Looks like it's a 1985 model.. Probably a Sports Coupe..
The tail lights look correct for a 1985 I have NO idea how that third brake light got on the roof.
Another weird thing about that third brake light, there weren't any until 86...or at least I didn't think so. I believe they weren't required by Uncle Sam until 86 or later...
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Kinda looks like a Corvette third brake light.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
What is interesting is the KC4 (Engine Oil cooler) with the LG4... I have never seen a car with that combo...
John
John
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Decent car with some nice options like the KC4 (mentioned by okfoz) and . . .
G80 - limited slip (nice)
J65 - front & rear disk brakes (nice)
BS1 - quiet sound group was standard on the Berlinetta and fairly rare in other models (around 2.7% of total production excluding the Berlinetta).
B48 - luggage compartment trim was also no cost to the Berlinetta although could be had with the "custom interior" on other models.
But I'd also say you definitly without a doubt have a Sport Coupe because . . .
C60 - air condtioning (not available on the Berlinetta, the Berl's got the C67 electronic AC)
. . . and because you don't have . . .
DK6 - roof console (standard on the Berlinetta)
B4Z - Iroc option package
D80 - rear spoiler (standard on the Z28)
. . . and because you do have . . .
U21 - special instrumentation (not available on the Berlinetta)
YE3 - convenience pkg #3 (not available on the Berlinetta)
Cool car.
Cool car.
well thats definitely not an american sold car for sure
leaded gas and canadian emissions ?
yeah
thats definitely not american spec lmao
very weird car
i see that its customer ordered/special ordered
one of a kind
hmm
yeah
very weird car
one of a kind
hmm
1 Post
Car: 1989 Camaro RS--
Engine: MPFI
how can that be this Camaro got no personality?lol it used to got the RS grill but i toke it off and throw it to the garbage,but Thank God its 85 model thnx for helping me out and is there any other info's about those RPO's and the weird big turn signals and the 3rd brake above the roof?
No kidding about raising old threads from the dead... As for the CHSML looking at it, the car is a 1985, Export, Europe I am not sure if it was after market or not.. I have to remember that Not everything is in the Parts catalogs, there may have been something with T89 : LAMP, TAIL & STOP, EXPORT which may be the high mount stop lamp, as the tail lights appear to be stock. I do not know when they dropped the Z28-E with the Amber turn lights on the outside and the red on the inside.
The side marker lights were standard fare when exporting to some European countries...
John
John
New2Chevy
09-28-2015 12:35 AM
