Need help with lower paint code...
Car: 87 Iroc
Axle/Gears: 3:27
This is what I came up with when decoding the codes...
AAA 1 P EQUIPMENT STANDARD FOR ABOVE VEHICLES
AR9 648 P STS M SEAT FRT BKT, DELUXE
A01 964 P GOT R WINDOW TINTED ALL, SHADED WINDSHIELD
BV3 2082 P ORNAMENTATION INTR, I/P, BLACK
B67 2482 P CONTAINER RADIO CASSETTE TAPES
B87 2554 P BSM R MOLDING B/S BLACK
B97 2590 P ORNAMENTATION EXTR, MLDG, LOWER ACCENT
C49 3708 P DEF R DEFOGGER RR WINDOW, ELECTRIC
C60 3771 P HTR M HVAC SYSTEM AIR CONDITIONER FRT, MAN CONTROLS
D14 4891 P CLC R CLUSTER COLOR INST, WHITE, CHROME RINGS
D3W 4955 P SFG M GEAR SPEEDO DRIVEN (D3W)
D35 4964 P MIR M MIRROR O/S LH, REMOTE CONTROL, RH MANUAL CONTROL, COLOR
D81 5140 P SPU R SPOILER RR, AERO WING
D88 5147 P DECAL STRIPE, SPORT
D9A 5149 P DIRECT SALES DELPHI INTERIOR & LIGHTNING, CONFIDENTIAL (A)
E5Z 6326 P SPA M ADAPTER SPEEDO - DELETE
E9Z 6470 P SPK M KEY SPEEDO - DELETE
GU2 8525 P RAX M AXLE REAR 2.73 RATIO
J50 12807 P BKS M BRAKE SYSTEM PWR
K22 13997 P GEN M GENERATOR 94 AMP
LG4 14503 P ENG M ENGINE DIESEL, 6 CYL, 7.8, DI, TURBO, DURAMAX
MX0 16407 P MTC M MERCHANDISED TRANS AUTO PROVISIONS, O/D
NA5 16880 P EMS M EMISSION SYSTEM FEDERAL, TIER 0
NK3 17238 P SWL M STEERING WHEEL SPORT, SOFT RIM, SIMULATED LEATHER
NDD 16960 FAMILY CODE NAVIGATION DISC DATA
T93 25914 P LAMP TAIL & STOP, SPECIAL
T96 25917 P LAMP FOG, FRT
UM6 26385 P RDO M RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV CASS, CLOCK, ETR
U21 26956 P CSR M CLUSTER INST, OIL, COOL TEMP, VOLTS, TACH
U66 27105 P SPR M SPEAKER SYSTEM 7, CUSTOM
VK3 27606 P LPF R LICENSE PLATE FRONT FRT MOUNTING PKG
V73 28434 P VCS M VEHICLE STATEMENT USA/CANADA
WW2 29333 P APP R APPEARANCE PACKAGE ACCENT #2
W62 29693 P EQUIPMENT GTO PERFORMANCE PACKAGE
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
6DB 41582 P FLH M COMPONENT FRT LH COMPUTER SEL SUSP (6DB)
7XY 43621 P FRH M COMPONENT FRT RH COMPUTER SEL SUSP (7XY)
8NB 44534 P RLH M COMPONENT RR LH COMPUTER SEL SUSP (8NB)
81U 47628 P CCU M PRIMARY COLOR EXTERIOR, BRIGHT RED (02)
84P 47494 P WHC R WHEEL COLOR GRAY (96)
9NB 45830 P RRH M COMPONENT RR RH COMPUTER SEL SUSP (9NB)
MD8 - TRANSMISSION, AUTO 4 SPD, THM 700 R4
N24 : WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE
WS4 – Model conversion – Trans Am
80A : STRIPE COLOR, ACCENT, TWO TONE, RED/DK SAPPHIRE
82B : TRIM COMBINATION, CLOTH, MED DK GRAY (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
199 SEAT BELT COLOR, BLACK (91)
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
While the F-bodies I've had were not a 85 they were a 84 and presently a 82. The 84 was a red and gold car but it's paint codes were 75U-75L. My 82's paint code is 19U-19L but it's a black and gold car.
I've always wondered why it didn't show a different lower color. I think it's because lower paint codes are for true two tone cars for instance my 1982 corvette is a two tone car and carries two different paint codes can't remember them off hand. The car is white on top and silver on the bottom though (paint scheme much like a 78 vette pace car)
I believe the bottoms of our cars are considered a "accent color" which is why the early ones had the same lower paint codes and possibly the 85up's didn't even have a lower paint code.
Or I am just wrong
Or I am just wrong
Re: Need help with lower paint code...
Just look up a silver color in paint books at like pep boys and for a 86 pontiac and you probably find the color & code
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
My 84 also has different-colord ground effects, but the color codes are the same. I think that the upper and lower color codes refer to two-color paint jobs on the body itself, but the ground-effects are a painted separately and installed after the body is painted.
ambainb
04-25-2016 09:21 PM
NBrehm
08-05-2015 07:57 PM
