84 Trans Am RPO code help
Car: 84 Trans AM, 89 Camaro
I just found My service parts identification thing. I was wondering if any one knows what all these codes mean. How many codes are normal? Mine has 5 1/2 lines of codes....... any help is appreciated
AAA AM9 AR9 AU3 AO1 A31 BS1 BV8 B20 B34 B35 B48 B97 CC1 CD4 C49 C60 DG7 D02 D1C D27 D34 D42 D53 D80 D85 E5Z E6E GT4 G80 J65 K19 K22 K34 L69 MK6 MM5 NA5 NB1 NOD NP5 N33 N65 N78 PB4 QYZ TR9 T93 UP8 UQ7 UT1 UU7 U21 U23 U25 U27 U29 U73 VD6 V73 WS3 WS4 WS6 WU1 W62 YR1 YS1 YT1 YT9 Y06 17C 17I 179 19A 6ZW 7ZW 75L 75U 8NM 84P 9NB
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
A01 = soft-ray glass
A31 = power windows
BS1 = extra sound deadener
B20 = luxury trim group
B34 = carpeted front floor mats
B35 = carpeted rear floor mats
B48 = luggage compartment hatch & trim
CC1 = locking hatch roof - removable
CD4 = Windshield wipers, cont cycle
C49 = rear window defogger
C60 = air conditioning
D42 = cargo security screen
K34 = cruise control
(absent) is MX0, automatic transmission, meaning this is a 5-speed car
L69 = 305 H.O.
NP5 = leather wrapped steering wheel
N33 = tilt column
TR9 = lamp group
J65 = rear disk brake package
GT4 = 3.73 ratio limited slip differential (probably Eaton Guv-lock)
WS6 = Well, you OUGHT to know what WS6 means!
N78 = High-tech turbo aluminum wheels in 15 x 7
W62 = aero effects package
Base radio, fixed-mast antenna, 5-speed WS6 Trans Am, the car probably weighs in at about 3500 pounds with half a tank a gas and no driver.
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Here's a partial list for you.
A31 = power windows
L69 = 305 H.O.
N33 = tilt column
TR9 = lamp group
A31 = power windows
L69 = 305 H.O.
N33 = tilt column
TR9 = lamp group
3500 lbs ummm I have a problem with that the 15th anni. car weighed less than that by at least 300 lbs i think source is road test of one from Motor Trend
thanks that helps out a lot. Is there a place that I can find the rest of them? I tried to download the rpo decoder but it was workin for me on this computer......
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
Where were all your codes located, I would like to look for mine. Thanks
inside the console or under the console lid, glued in place, only in 84-up
thats a really nicely optioned out car you have
so is mine but i have more accessories like power antenna and the high end for the day speaker system and of course the colors are a lil different.
well as of now i couldn't tell you. If my brother sends me the codes so i can decode it then i will let you know. But I am in school 1400 miles away from my car. I think your sound system popped up when i ran the codes let me go through them again and i will let you know.
I ran your code through again and
UQ7= Speaker system, 5, Dual I/P, Sail Mounted Standard Speaker
My dad says that the one in our car was the highest option sound system but I will have to wait until my brother sends me the codes to confirm that.
hectre13
12-11-2023 08:14 AM
