carfax sonfused me...
looked up my car on carfax...
it says...
"1988 PONTIAC FIREBIRD TRANS AM/GTA (1G2FW21E7JL226216)"
So my car is a GTA? or what?
there where 16 records, mostly updates and transfers with to failed emissions...
deleted content...no sharing carfax accounts. It's a violation of their user agreements.
it says...
It does that for some reason for example my 91 is a base firebird with a 305 but it says "Firebird/Formula, doesn't mean it's an actual Formula.
Im guessing yours must be a TA.
1 Post
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
the vin's dont actually distinguish between trans am/gta and firebird/formula. Theres a vin digit for the model and one of the digits signifies Trans Am OR GTA and the other digit signifies Firebird or Formula. if that makes any sense. someone will probably be able to explain it better...
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
it says...
Also if anyone is interested i can post username and password so you'all can look up yours (its been passed arounf a couple of my other forums)
it says...
So how can i find out if its a GTA?
the hood was efertmarket when i got it, he removed all badging and decals etc... and he put a different hatch on it because his rear window got broke and a whole hatch was cheaper so...
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
there should be something in the vin or RPO codes but idk much about pontiac third gens...deleted content. No carfax requests allowed on TGO.
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
Don't give up so hastily. Contact Pontiac Historical Services, give them your VIN number, and they'll send you everything they have on your car. Things like the dealer invoice, build sheet, etc. Definitely worth a look. Search for them through Google.
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Your car isn't a GTA because the 8th digit in all GTA's was "F" for 305 TPI or "8" for 350 TPI. Since yours in an "E", yours would be a 305 TBI.
david068513
09-18-2015 10:36 AM
