Original Decals location.
#51
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Original Decals location.
Hey okfoz, the stock springs on my car have a number on them, ill try and take a pic of the fronts since i painted the rears.
#52
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
There is usually a sticker on each of the springs that has an RPO and a part number...
#53
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
Here is my 1985 IROC LB9 California emissions lable.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
#54
hi everyone,i have a 84 camaro z28.the hood has black stickers where the louvers go.my question is,will the louvers from a 85 to 92 iroc fit on my hood? is there any differance in size?
#56
#57
Car: 89 IROC-Z
thats what mine looked like! to bad i sanded and painted them before i got a pic
#58
i posted this question awhile back ,guess nobody has a answer,i guess i'll have to go to a chevy dealer to get an answer.
#59
The 82-84 hood is different than the louvered hoods. You cannot install the louvers on an 84 hood. You need to locate an 85-92 Z28 hood.
#60
To add to what scott said.. I want to think that the area on the 82-84 style hood was narrower than the 85-90 style hood... So as Scott stated you would need a different hood for them to work correctly...
John
John
#61
#62
thanks again,i have the car ready to get painted,so i'll just stay with what i have,thanks.
#63
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Kevin
The UNJ on that label is the "Label Code"
The second line is the "Engine Size"
The third line is the "Exhaust Emission Family"
The fourth line is the "Evaporative Emission Family"
The above is from the 1982 Camaro Service Manual, Fig 6E1-1 "Vehicle Emission Control Information Label"
The ECM prom type is on the ECM label. Below is the ECM from an 82 CFI car, with Engine Code 7.
The ASY in the upper left corner is the prom code in this ECM. I have a photo of the electronics on the inside, but you can barely make out the ASY on the prom due to flash washout. The Prom is the chip in teh top center of the photo.
Dave
#64
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I have pics of small bird placements and wording placements on a 86 T/A
Rear Bumper
Right sail bird
Rear Bumper
Right sail bird
#65
Engine: Broke - 350
Right sail bird
Right fender writing
#68
Engine: Broke - 350
Front lettering
Center nose bird
Center nose bird
#69
bestracing,
thanks... I will be honest, there is no exact location, the factory had a rough placement for the decals and that was close enough. But what you have given is beneficial. Thanks.
It should also be noted that typically the Trans Am decals on the front and rear bumpers were typically lower without the stripe....
Thanks again.
John
Thanks again.
John
#70
Engine: Broke - 350
At least it will get people in the ball park ![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
I have some OEM supension stuff on my 86 that still has the stickers. I just have to remember to get pics of it when I'm under there again to fix up the rear housing this winter. I won't forget....
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
#71
Car: 1989 Firebird
Engine: 2.8L V6
Bestracing....Do you still have the measurements of the decal locations for the sail and the nose stickers? I tried to see from your pictures but could not make some out. I just painted my 89 firebird and wanted to redecal it. Thanks for your help!
#72
Sticker on driver side rear shock of my 1985 IROC with NNN springs.
#73
#75
https://www.thirdgen.org/forums/atta...n-sticker2.jpg here is a bigger pic. It says The spark plug gap has been changed to 0.035 inches per chevrolet campaign bulletin number 85-c-22
#76
I think I found the answere in the Chevrolet Dealer service bulletin # 85-93 section 6. june 1985. High output ignition coil replacement.
#77
Engine: Broke - 350
Sorry I haven't checked this out lately but yes I do have the numbers. Once I get home to my computer I'll post them up. The original pictures are huge so I had no problems seeing them but didn't look back at it after resizing them.
#78
Engine: Broke - 350
Nose is 1 7/8" from hood edge
Sail panel is 3 1/4" from the window edge and ~1 3/8" up from the body line to the line on the bird.
Maplehawk (09-01-2020)
#88
Car: 1989 GTA
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Can anybody tell me the correct decal for the rear bumber on a 89 GTA ? I've gotten different answers.
One answer was the "5.7 tune port injection" medalion in gold located on the drivers side.
Another was "Pontiac GTA" decal in gold located on the passenger side.
Or did they come off the assmbly line with any at all ?
So much aftermarket crap !!!
Thanks in advance
Thanks in advance
#90
There was no "5.7 Tuned Port Injection" badge on the GTA. There also was no badges or emblems on the GTA's bumper. It's the Trans AMs that would come with "Trans AM" scripts written on the bumpers, and on the driver doors for the later Third Gen Trans Ams. It's also the Trans AMs that would (at times) advertise engine size on the fender. This wasn't on the GTA.
Pontiac should be embossed in the center of the rear bumper on your 1989. That's all that's on the rear bumper of the GTA.
For 1989, you should have two sail panel badges (one per sail panel):
![](http://www.gtasourcepage.com/authenticationpics/sailemblem2b.jpg)
You should have two GTA emblems on the fender (one per fender):
![](http://www.gtasourcepage.com/authenticationpics/fenderemblem.jpg)
You should have one, metal, badge on the front bumper in the center:
![](http://www.gtasourcepage.com/authenticationpics/noseemblem.jpg)
You should also have one Pontiac, in gold lettering, script on the driver's side headlamp door:
![](http://www.gtasourcepage.com/authenticationpics/golddoor.jpg)
Finally, you should have one emblem, in gold, in the center of the tail lamps :
![](http://www.gtasourcepage.com/authenticationpics/goldbird.jpg)
Thanks to Frankie's GTA Source Page website for the images above.
Thanks in advance
Thanks in advance
#91
Car: 1989 GTA
Engine: 5.7 ltr.
Excuse me members for not calling the rear bumper by the correct description.
Thanks for the info and the pics JT...I assumed such, just needed some verification from the board..I come to this site for advice from knowledgeable experts like you all on these cars, and I take that advice seriously..
Again thanks...
As for Jeff....Back at ya...Everybody likes a little a$$, but nobody likes a smart a$$..
Again thanks...
#92
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Here's some pics off my stock & original '89 IrocZ convertible (Canadian model) . . .
Trunk caution decal
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280377_large.jpg)
Trunk lid VIN tag
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280376_large.jpg)
Trunk lid jacking instructions decal
Trunk caution decal
Trunk lid VIN tag
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280375_large.jpg)
#93
Axle/Gears: 3.08
Left door Canadian weight/prod tag
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280374_large.jpg)
AC compressor tag
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280373_large.jpg)
Another AC related decal located on the top of the blower fan box
AC compressor tag
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280372_large.jpg)
#94
Axle/Gears: 3.08
Side of wiper motor
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280371_large.jpg)
Front of brake fluid reservoir
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280370_large.jpg)
Side of air intake box
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280368_large.jpg)
#95
Axle/Gears: 3.08
Tonneau cover roof latch warning decal
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280366_large.jpg)
ID/VIN door tags
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280365_large.jpg)
ASC driver's door decal
ID/VIN door tags
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280364_large.jpg)
#96
Axle/Gears: 3.08
Door tire loading decal
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280362_large.jpg)
Under hood near latch VIN decal
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280361_large.jpg)
Under hood 5.0L TPI emission decal
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280360_large.jpg)
#97
Axle/Gears: 3.08
Emission routing decal (I believe it is on the under surface of the hood)
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280359_large.jpg)
PASS-Key theft-deterrent system window decal
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280358_large.jpg)
Of coarse we can't forget the SPID
![](http://carphotos.cardomain.com/ride_images/1/2103/561/5255280322_large.jpg)
I have a lot more but I'll need to locate the pics.
#99
Engine: 4++,350 & 305 CIs
If you have original decals, the paper properly locates the decal on the hood and doors.
The door decals are high/low depending on stripe/ no stripe and how the installer felt that day.
F/R bumpers were on the right side (as looking at them) I know on the rear bumper the end of the formula decal ends around about straight down from where the decklid/quarter gap is. I think the front bumper formula decal is about the same with the hood/fender gap.
Sail panel birds are also all over the place.
Front bumper bird has a locating paper backing.
I think the service manual may also have measurements of the correct location.
#100
I don't believe there is an exact measurement...
Tony is right about the doors... The non stripe cars seem to be lower, but my Formula 350 Convertible is definitely higher on the door than I prefer. I go by the rule of thirds... It is where they look the best, After I painted mine I took the decals and I taped them to the door... I moved them up.. and down, until they looked right...
I think have measurements written down somewhere, but I might not be able to find my book.
The front and rear bumpers, is true to what Tony said...
The front bird should be in the center of the facia
Edit 2:
IIRC The sail panel birds are something like 2.75 behind the window highlight line to the wing, and 2.75" above the quarter highlight line roll to the tail feathers
Edit 2:
