RPO codes, is this about normal?
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
AC3 ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9 ADJUSTER, SEAT, POWER, 6 WAY
AM9 SEAT, RR, SPLIT, BACK, FLDG
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 LOCK CONTROL, SIDE DR, ELEC
A01 WINDOW, TINTED, ALL SHADED, W/S
A31 WINDOW, POWER OPERATED, ALL DOORS
A90 CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B18 ORNAMENTATION, INTR, DELUX
B2L PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
B34 COVERING, FRONT, FLOOR MATS, CARPETED INSERT
B35 COVERING, REAR, FLOOR MATS, CARPETED INSERT
B48 TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B6T ?
B84 ORNAMENTATION, EXTR MLDG, BODY SIDE
B91 ORNAMENTATION, EXTR MLDG, DR EDGE GUARD, COLORED
CD4 WIPER SYSTEM WINDSHIELD, PULSE, VARIABLE DELAY
C49 DEFOGGER, RR WINDOW, ELECTRIC
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C95 LAMP, INTR, ROOF, COURTESY AND DUAL READING
DG7 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, COLOR
D34 MIRROR I/S FRT VAN LH & RH, SUNSHADE, NO ILLUMINATION
D42 SHADE, RR COMPT SECURITY
D6M GEAR, SPEEDO DRIVEN
D80 SPOILER, RR END PNL
D88 DECAL, STRIPE, SPORT
E5Z SPEEDOMETER ADAPTER (DELETE)
E7Z SENSOR VEH SPD - (DELETE)
E9Z SPEEDOMETER KEY (DELETE)
FE2 SUSPENSION SYSTEM, RIDE HANDLING
GW6 AXLE REAR, 3.27 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
G92 AXLE REAR RATIO, PERFORMANCE
J65 BRAKE SYSTEM, PWR, FRT & RR DISC
KC4 COOLING SYSTEM, HEAVY DUTY ENGINE OIL
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0 MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NP5 LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N33 STEERING COLUMN, TILT TYPE
N65 WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N96 WHEEL, 16 X 8, CAST ALUMINUM
PB4 LOCK CONTROL, WHEEL
QDZ TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9 LAMP, GROUP
TT4 HEADLAMPS, HALOGEN, 4
T93 LAMP, TAIL & STOP, SPECIAL
T96 FOG LAMPS - FRONT
UM6 RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV CASS, CLOCK, ETR
UQ1 RADIO PROVISIONS, FOR STEREO
U25 LAMP, INTR, RR COMPT, COURTESY
U26 LAMP, INTR, ENG COMPT, COURTESY
U29 LAMP, INTR I/P, COURTESY
U79 SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN ASSEMBLY PLANT, VAN NUYS, CA
VK3 LICENSE PLATE, FRT MOUNTING PKG
V73 ANTENNA, FIXED
WW8 APPEARANCE PACKAGE(BRIGHT RED), AERO #8
W62 EQUIPMENT GTO PERFORMANCE PACKAGE (AERO PACKAGE)
X07 ?
YR1 SEAT,FRT CUSTOM
YS1 SEAT,RR CUST
TY1 PARTS PKG MISCELLANEOUS CHEYENNE
Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
Z31 IDENTIFICATION PRICE SHEET ADVANCE
Z49 EXPORT CANADIAN MODIFICATION MANDATORY BASE EOUIPMENT
15P WHEEL COLOR SILVER METALLIC (91)
19C TRIM COMBINATION, CLOTH, BLACK (C) (91)
19I INTERIOR TRIM, BLACK (I) (91)
199 SEAT BELT COLOR, BLACK (91)
6ZW SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZW SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL SPRING, COMPUTER SELECTED, REAR, LEFT HAND
81Q MOLDING COLOR, BRIGHT RED (91)
81U PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
86A STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9NL SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
K68 GENERATOR,105 AMP
L98 5.7-LITER V8 TPI ENGINE
Only 2 RPO codes I couldn't get. X07 and B6T any ideas?
Otherwise, is this pretty normal for a 1988 IROC?
B6T ?
TR9 LAMP, GROUP
V73 ANTENNA, FIXED
X07 ?
YR1 SEAT,FRT CUSTOM
YS1 SEAT,RR CUST
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
You have a very nice and heavily optioned '88 IROC.And with the 350 on top of it.
