iroc or not iroc
Car: 89 iroc
Axle/Gears: dana44 3.73
iroc or not iroc
just wandering if anyone knew an easy way to tell if your car is accully an iroc/z28 im looking to buy a 89 convertable just want to make sure it is what he says it is not just stickers on the car
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
dash emblem,steering wheel,rims,taillights,hood,145 gauges..etc check for factory iroc options vin# and if it is a tbi Iroc I guess it realy doen't matter
I don't think you will find B4Z on the later model years where there wasn't a distinction between the regular "Z28" and the "IROC-Z". On the later cars (not sure which exact years), they will show Z28 as the RPO. Contrast that to my '85 which does show B4Z as a separate RPO.
Mike M
Mike M
Incorrect. Not for 1989.
For 1985 to 1987: The regular Z28 was designated by, you guessed it, the Z28 RPO code. The IROC-Z was designated by B4Z.
Again this is incorrect, as IROC-Z is simply short for IROC-Z28. The option code for these years is Z28. Basically in these years all were both, unlike in 1985 to 1987 where you could have a Z28 that is not an IROC-Z.
The bottom line is all IROC-Zs are Z28s, but not all Z28s are IROC-Zs. In essence the IROC-Z is simply a higher optioned Z28.
There was not a Z28 from 88-90, the IROC was a standalone model. Prior to 88 MY the IROC was an option for the Z28. Chevy dropped the Z28 for the 88-90 MY, but the RPO was Z28 for an IROC car.
In your case, you should have Z28 on the RPO sticker.
That makes no sense. How can you say that an 88-90 IROC-Z is not a Z28 when the RPO code is Z28. Hell my 90 IROC-Z says Z28 in huge letters on the dash. Would you like a picture of the badge? As I said above all IROC-Zs are higher optioned Z28s. How can you not see that? Just because GM eliminated the lower Z28 doesn't mean the IROC-Z was now not a Z28 even if it is it's own model.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
cdartz is correct in all aspects. In 85-87, the IROC-Z was a sub model of the Z28. You could order either car. The IROC-Z was an option package. In 1988-90, GM dropped the IROC-Z option package. The performance model for the Camaro was still the Z28. Only now, all Z28s came with the IROC-Z option package as standard. So in essence, as cdartz stated, all IROC-Zs were Z28s or Z28s with the B4Z option package.
GM was reducing the model count starting in 88. The Z28 and the IROC-Z were merged into a single model eliminating the need to have 2 models. All the other Camaro models were merged into the Sport Coupe. You could get a base SC or you could get one optioned almost as well as a Z28. With only 2 models to choose from, it made life easier for GM and parts certification.
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
That's why. All IROCs (including TBIs) had stiffer spring rates, larger diameter swaybars, and wonderbar that the RS never had ...even the F41 suspension upgrade for the RS was a softer suspension than the FE2 package on IROCs ...so there were more differences than just the engine and badges.
The VIN does not dictate if the car is an IROC-Z. The only time the VIN would tell you is based on the engine designation of "8". The IROC-Z and 91/92 Z28 were the only cars available with the the 350. Other than that, the VIN does not tell what you have. In this case, the car in question is a convertible, so no "8" in the VIN.
Car: 89 iroc
camaro
well i picked it up today it was told it had a 305 tbi in it stock now it has a 355 carb.It has 15in iroc wheels,fog lights,it does have the iroc dash emblem ? either way i got it cheap even if its an rs.I have seen irocs with the 15in wheels, and i seen z28 with the 110/115speedo witch this does have,about the biggest thing i noticed that threw me was the 10 bolt drum rear i thought by 89 irocs all had nine bolts i looked in the console theres no codes in there stickers gone PS just to ask i do need a center spoiler piece if anyone has an extra lying around ha ha good luck right thanks for all the info
Regardless of any parts that are physically on the car, you won't know for sure unless you have the SPID. Anyone can remove parts from one car and put them on another. Fbodies are very popular cars to the modification happy crowd, and to think that a rear end or badging, or wheels wouldn't be changed in 15 years is ignorance. Get the documentation when you buy, or dont pay a premium for a car that's supposed to be an Iroc.
Car: 87 IROC-Z
Transmission: automatic
Not entirely true. In 87 and 88 G92 was available on 305 TPI with automatic which included the 3.23 Ten bolt rear end. I have one.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
After reading this topic, I must say Cdartz knows his stuff.
For examples of what's been talked about and for another '89 Iroc vert to compare to, here's mine . . .
My RPO list printed from a GM dealership after running my VIN through there system . . .
No longer a B4Z rpo, but does have the Z28 rpo.
Here is a pic of the Z28/IROCZ dash plaque . . .
And as Scottmoyer mentioned, there's no 8 in my VIN (see top of RPO list above). Sadley no verts came stock with a 350. At least they didn't twist themselves apart to bad then. So as mentioned the VIN really tells you nothing to help determine if a vert is an Iroc.
The LO3 (305 TBI) and the LB9 (305 TPI) were both available on the IROC vert.
IROC's had black painted headlight buckets (as long as it's nobody's changed it).
I believe all '89 verts came with 115mph speedo's regardless of engine or model, so you can't really go by the gauge.
Please correct me if I'm wrong on anything. I was scratching what few braincells I have left, on this post.
A lot of the other things could have been changed over the years, making it quite hard to determine an IROC if a previous owner(s) wanted it to.
Actually, B2L has nothing to do with the Iroc package. B2L is defined by GM as... 'Engine Package - V8 5.7L, PFI'. L98 is defined as 'Engine, 5.7L V8'. The two are related, but not identical codes. Much the same as MD8 and MX0 which both relate to the 4spd automatic transmission. MD8 literally is referring to the 700R4/4L60, while MX0 is the automatic transmission merchandising option. Basically B2L specifies various parts related to the engine, nothing more. B2L isn't an Iroc specific code.
1 Post
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
I got a '87 305 TPI with the ten bolt posi 3.23!(option codes: G80, G92, J65)
My friend has a '88 convertible with 15 X 8 inch rims. (16 inch rims in '88 on were now an option and not standard like they were in 85-87)
All Iroc-z after '87 have the iroc-z emblems on the ground effects instead of the Z-28 ones, but still have the Z-28 on the dash.
Don't know if you guys have seen this site before, lots of good info:
IROC-Z.com
-Nick.
IROC-Z.com
-Nick.
I hate to nitpick, but honestly, you're posting incorrect information that will only serve to confuse people looking for a fast way to verify if their car is an Irocz. If they go looking for B2L on a Camaro with B4Z and a 305, it's not going to be there, while the car will indeed be an Iroc since it carries the B4Z code.
Thanks Drew. You saved me some typing. Now this link above appears to be alive again! It's been down for quite some time. Maybe Jeff has taken the time to get update it's information. There is a lot of bad information on that site also.
We just had a similar discussion on another thread regarding RPOs. Sure enough, someone post up with a description of what an Iroc really is and in what years, blah blah blah.
The bottome line is the ONE RPO CODE. Z28/B4Z for 85-87, and Z28 for 88-90.
Forget motor, suspension, rear, gear, color, badge, wheel size, carpet color, and the price of spaghetti. It either has ONE all encompassing RPO or it doesn't.
My brain hurts when so many people say the same thing over and over and then somehow find a way to argue over it.
mustangman65_79
08-11-2015 03:17 PM
