Formula 350 with T-top???
Old 05-19-2006 | 08:39 PM
BlackBird20's Avatar
Car: 88 Formula 350
Engine: Hopes and Dreams
Transmission: Slush Box
Axle/Gears: 9 Bolt, 3.27
Well, I had a little scuffle with this one guy the other week about no Formula models with the TPI 350 were T-tops... He says that it doesnt matter, a T-top Formula could have the TPI 350... I disagreed... I think I read somewhere that all Formula 350's were ALL Hardtop, is this correct?? And if so, why??
Old 05-19-2006 | 08:42 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
You could get a Formula L98 (350) with T-tops.
EDIT: Here you go... https://www.thirdgen.org/forums/hist...ight=350+T-top
Old 05-19-2006 | 08:51 PM
Car: 88 Formula 350
Why is it all the option list for the Formula models with the L98 option require the T-top delete.... CC1 ??? Or was I misreading something
Sorry it's so long, but here is a list of options for a 92, 87-91 is the same for the engines... Notice it says for the L98 "cannot include CC1"
A also say this because I have never seen a Formula T-Top car with the L98 engine... I've seen quite a few and there a over 20 Formula's i've seen in my area, all with T-Tops are either the LB9 or LO3
EDIT, Alright, I read the thread... So there are few and far between I take it
Regular Production Options (RPO)
Description
RPO Code
Price
Weight
Standard Equipment AAA
4 Way Manual Seat Adjuster
AH3
$35.00
Drivers Side Inflatable Restraint AJ3
Restraint Provision, Child AN4
Articulating Buckets
AQ9
$450.00
Recliner Bucket (European Style)
AR9
no cost
Power Door Locks
AU3
$210.00
3.1
Glass, Soft Ray, All Windows
AO1
Standard
Power Windows
A31
$280.00
3.9
Override Canadian Requirements A4G
Power Hatch Release w/Pull Down in Trans Am
A90
$60.00
Ornamentation, Interior, Door Pocket BC8
Ornamentation, Interior, Black BV3
Engine, 5.7L, V-8, BC, HO, TPI
(Requires MXO, KC4, WS6, J65, G80)
(Can Not include CC1)
B2L ( L98) $1045.00
Luxery interior with metix cloth trim in Trans AM
B20 $293.00
Noise Control B3E
Carpeted Front Floor Mats B34 $35.00
Carpeted Rear Floor Mats B35 $35.00
Container, Cassette Tape Storage B67
Moldings, Vinyl Body side (Black) B84 Standard 1.3
Locking Hatch Roof w/removable Glass Panels CC1 $920.00 29.5
Controlled-cycle Windshield Wipers CD4
Heater w/Defroster, Outside Air C41
Electric Rear Window Defrost (except GTA) C49 $170.00 0.9
Air Conditioning C60 $830.00 41.7 with V-6
42.6 with 305 TPI & 700R4
46.3 with 305 TBI & 700R4
42.7 with L98
Rear View Dual Reading Lamp DC4
Electronic Day/Night Mirror DD8
Mirror, Outside Rear view Electric Remote DD9
Rear Window Shade DE4 18.5
Electric Side Mirrors DG6 1.3
Sport Electric Power Mirrors DG7 $91.00
Roof Console Subwoofer Controls
DK6
T/A Hood Appliqu馮bsp; DX1 $95.00
Arm Rest, Front Door D14
Speedometer Driven Gear
D3V
D3W
Speedometer Driven Gear D3Y
Mirror, Visor Vanity, RH D34 0.4
Mirror, outside, rearview painted D35
Cargo Screen
D42 $69.00
Speedometer Driven Gear D5S
Speedometer Driven Gear D5T
Speedometer Driven Gear D5V
Speedometer Driven Gear D5X
Color Over-ride D60
Deluxe Two-Tone Paint D66 $150.00
Speedometer Driven gear D7C
Speedometer Driven Gear D7H
Speedometer Driven Gear D7J
Speedometer Driven Gear D7L
Speed Sensor D8E
Speed Sensor D8F
Speed Sensor D8G
Spoiler, Deck Lid Rear D80
Aero Spoiler
D81
Rally ll
D83
Paint, 2 Tone (Deluxe)
D86
Vehicle Speed Sensor D9A
D9B
Vehicle Speed Sensor D9E
Stripe Accent D98
Speedometer Adapter (Delete)
E5Z
Speedometer Key (Delete) E9Z
Suspension System, Soft Ride FE1
Suspension System, Touring Ride & Handling FE2
Suspension
F41
-6.6
Axle, Rear 3.45 Ratio
GM3
Axle, Rear 2.73 Ratio GU2
Axle, Rear 3.08 Ratio GU4
Axle, Rear 3.23 Ratio GU5
Axle, Rear 3.42 Ratio GU6
Axle, Rear 3.27 Ratio GW6
Limited Slip Differential Axle
G80 $100.00
Axle, Performance Ratio
G92
Trim Interior Design ILC
Trim Interior Design IL2
Trim Interior Design IPC
Shaft, Prop (Aluminum) JG1
Brake System, Power, Disc/Drum (Cast Iron) J41
Brake System, Power, Disc/Drum (Aluminum) J42
Brake System, Vacuum Power J50
Four Wheel Power Disk Brakes J65 $179.00 2.6
Oil Cooler KC4 $110.00
Engine Block Heater, K05
Cruise Control w/Resume Feature
K34 $225.00 5.3
Generator, 100 AMP
K60
Generator, 105 AMP
K68
Generator, 85 AMP K99
Engine, 5.0L, V-8, TPI
LB9 $745 Formula & T/A
($300 credit GTA only)
Engine, 3.1L V6
LHO
Engine, 5.0L V8, TPI
LO3 $350.00 (base only)
L98
(B2L)
$300.00 in T/A
$1045.00 in Formula
Transmission, 5-Speed Manual
MB1
Transmission, 4-Speed Automatic
MD8
Transmission, 5-Speed Manual MK6
MM5 No Charge ($515 Credit in T/A)
Transmission, Automatic, 4Spd
MXO $530.00 exc GTA 101.9
M39
Emission System, Federal Requirements
NA5
California Emmissions NB2 $100.00
Emission System, California Override NN5
Steering Wheel, Leather wrapped
NP5
Formula 3 spoke Leather Steering Wheel
NK3
Exhaust System, Dual
N10 $155.00
Wheels, 15 x 7" Finned Turbo Cast - Alum
N24 $215.00
Steering Wheel - Tilt
N33
Wheel, Sport Steering
N36
Wheel & Tire Spare, Aluminum N64
Wheel & tire, Stowaway Spare N65
Wheel, 16 x 8 Styled (Aluminum) Formula
PE0 No Charge
Wheels, Diamond-Spoke Aluminum GTA/T/A
PW7 No Charge
Inflator, Spare Tire Delete P43
High Performance Tires WS6 P245/50R16 QLC $315.00
Tires, P215/65R15
QNS No Charge
Tires, P215/60R16
QPE No Charge
Tires, P215/65R15
QPH No Charge
Tires, P215/65R15 Steel Belted Black walls
QYZ No Charge
Performance Enhancement group with Dual Converter, 4 wheel disk Brakes, Engine cooler & more. RP6 $265.00
Trans Am Value Package R6A $889.00
Firebird & Formula Value Package R6A $820.00
GTA Value Package R6A $1020.00
Firebird & Formula Value Package R6B $814.00
Articulating Performance Seats (Ultima)
TBD
Lamp group
TR9 $34.00
Daytime Running Lamps T61
Smoked Lenses, Tail Lights T93
Fog Lamps T96 4.4
Heavy Duty Battery
UA1
Theft Deterrent System UA6
Instrument Cluster UB3
Lamp, Interior, Console & Courtesy
UF6
Radio, Japanese Freq UK1
AM Radio Delete UL5 $56.00 Credit -5.7
Delco Am/Fm Stereo w/seek-scan w/ Cassette
UM6 $150.00
Delco Am/Fm Stereo w/seek-scan & clock
UM7 $217.00
Radio/Stereo Installation Provisions
UQ1
Buzzer, Tone Generator Warning
UT1
Delco Am/Fm Stereo Cassette w/graphic EQ
UX1 $150.00
Delco AM/FM CD with EQ
U1A $226.00-$376.00
Speedometer (KM)
U18
Speedometer (Canadian)
U19
Rally and Instrument Panel with Tach, Gauges, Trip Odometer in Base Firebird
U21 $150.00
Hatch Compartment Lamp
U25
Instrument Panel Curtsey Lamp
U29
Speaker System Dual Coaxial (Delco Bose)
U62
Power Antenna (Chrome)
U75 $85.00 2.6
Speaker, 4 Dual Front Coax, Dual Extended Rear (Delco Bose)
U79
Front License Plate Mounting
VK3
New York Warranty enhancement WDV
Firebird Performance value package #1 WS1 $265.00
T/A Performance value package #1 WS1 $839.00
Firebird Performance value package #2 WS3 $709.00
Trans Am Package
WS4
Special Performance Package
WS6 No Charge on Formula & GTA
($385.00 T/A only)
Aero Package #1 (white) WW1
Aero Package #2 (silver) WW2
Aero Package #3 (gunmetal metallic) WW3
Aero package #4 (black) WW4
Aero Package #6 (flame red metallic) WW6
Aero Package #8 (bright red) WW8
Aero Package #10 (bright Blue Metallic) WY8
Two Tone Lower accent Paint Delete Firebird and Formula Only WX1 $150.00 Credit
Aero Package W62
Formula Option for Base Firebird
(Includes LG4, QDZ, N96, WS6, U21)
W66 $1070.00
Firebird Sport Appearance Option W68 $450.00
Firebird Package Y81
Trans Am Package
Y83
GTA Option for Trans AM
(Includes B2L, QDZ, PW7, WS6, KC4, J65, G80, DD9, NP5, B34)
Y84 $2700.00
Rally Turned Suspension
Y99 $59.00
Canadian Base Equipment Z49
Performance Package 1LE
Firebird option Group #1 1SA
Formula option Group #1 1SA
Trans Am option Group #1 1SA
Firebird V6 option Group 1SB $888.00
Firebird V8 option Group 1SB $33.00
Formula option Group #2 1SB $223.00
Trans Am option Group #2 1SB $223.00
Firebird V8 Conv option Group 1SB $225.00
T/A conv d option Group 1SB $183.00
Firebird V6 option Group 1SC $979.00
Firebird V8 option Group 1SC $419.00
Formula option Group 1SC $419.00
Trans Am option Group 1SC $384.00
Other Option groups 1S(x)
Package Discount 1SZ
Molding Color (White) 11Q
Wheel Color (Silver Metallic) 12P
Secondary Exterior Color (Silver Metallic) 13L
Wheel Color (silver metallic) 15P
Wheel Color (Silver) 16P
Wheel Color (Charcoal metallic) 18P
Trim Combination 19C
Trim Combination 19D
Interior Trim 19I
Wheel Color 19P
Molding Color (black) 19Q
Interior Trim (Black) Leather 192
Safty Belts (Black) 199
Molding Color (medium Maui Blue metallic) 23Q
Exterior Color (medium Maui Blue metallic) 23U
Molding Color (Bright Blue metallic) 24Q
Exterior Color (Bright Blue metallic) 24U
Molding Color (White) 40Q
Exterior Color (White) 40U
Molding Color (Black) 41Q
Exterior Color (Black) 41U
Exterior Color (medium green metallic) 45U
Wheel Color (Gold Metallic) 52P
Accent Stripe (Red/Black/Gunmetal) 76A
Accent Stripe (Red/Gunmetal/Silver) 78A
Old 05-19-2006 | 09:21 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
here you go... Formula 350 with T tops
Old 05-19-2006 | 09:33 PM
Car: 88 Formula 350
Thanks guys... So are they rather on the rare side???
92 Formula's Avatar
Engine: Twin 454's
A bit more on it:
https://www.thirdgen.org/forums/hist...ula+350+T-Tops
Old 05-19-2006 | 09:38 PM
Car: 89 Formula 350
not as rare as the formula 350 convertables, theres another formula 350 T Top car on my block but it's a junker
Old 05-19-2006 | 09:44 PM
Car: 88 Formula 350
So Firebirds could get the L98 in a convertable, but the Camaro's couldn't... Sorry to ramble off a bit more..
Old 05-19-2006 | 09:47 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
ive seen two 91/92 formula 350s with t-tops. iirc they were the only 91/92 L98 car to get away with t-tops for some reason.
Old 05-19-2006 | 11:26 PM
Guest
Guest
Posts: n/a
Ummm...errr... well, not exactly. The L98 convertibles (ASC converted cars) were not blessed by GM with a convertible VIN number. So, yes there were L98 convertibles made by the same people that brought you the LB9 convertible, but the VIN wont tell you that.
<--- 89 L98 GTA vert owner
Old 05-22-2007 | 05:15 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: Formula 350 with T-top???
Old 05-22-2007 | 06:39 PM
92 Formula's Avatar
Engine: Twin 454's
Originally Posted by 89formula350b2l
Wow, you bring up a year old post just to post that you're wrong? '91 Formula's could be had with both the L98 and T-tops. There are several members on this board who have them, MDFormula350 or something like that is one of them and a Canadian guy has a red one.
Old 05-22-2007 | 07:36 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Yes, the Formula was the only model in 91-92 that could get t-tops and the 350.
Old 05-22-2007 | 08:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
try finding a late 80's formula 350 with OUT T Tops. its darn near impossible. lol VAST majority have T Tops
Old 05-22-2007 | 09:13 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
I have a 1987 formula with t tops and a 350. Just finished getting it in!
Old 06-03-2007 | 11:59 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
so true glad I own one
Old 06-04-2007 | 09:14 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I would REALLY be interested in seeing your SPID sheet as I have never seen an ACTUAL 87, 88 or 90 Formula 350 with t-tops
As for FOrmula 350's & T-tops U have one, its an 89, actually its an ASC convertible...
The biggest reason why Pontiac did not offer T-tops on the GTA & Trans Am in 1987 & 1988 was mostly due to the fact that it would have lowered the fuel efficiency and the cars would have been classified as a "Gas Guzzler" therefore instead of paying $995 for T-tops you would have paid $1995 for that same option, so they did not make it readily available until 1989 when they updated the injectors, intake and some minor refinements to the program to allow for better fuel efficency... In 1990 this went away because of the new computer design...
As for ASC not being blessed by GM & ponitac... I suspect that Pontiac wanted a convertible from 87-90, it would have been a huge disadvantage for them by not offering a convertible... THe problem again comes back to the fuel efficency of the car, because the Vert was heavier than the regular hard top cars, and the lack of aero, this would have placed the cars into a different Gass Guzzler bracket and again the consumer would have spent an extra premium to buy the cars, it was not feasable... To get around this they allowed ASC to let dealers convert cars AFTER the production process.. Fortunately this process was identical to the ones the Camaros had BUT it was not classified as a Convertible on the VIN. This way Pontiac could offer a convertible under the table...
BTW, I get 25 mpg highway in my vert with the top up
John
BumpaD82
Members Firebirds
31
04-04-2019 10:36 AM
okfoz
Convertibles
83
10-29-2018 11:18 PM
okfoz
03-09-2017 02:35 PM
Linson
08-31-2015 04:52 PM
Quick Reply: Formula 350 with T-top???
