Wentzville, MO assembly plant????
Car: 1984 Firebird S/E
Engine: 350 V8, 4 barrel carb
Transmission: 700 R4 automatic overdrive
My son just bought a 1992 Firebird Formula with the L03 TBI engine. Upon running the VIN number, it came back that this car was built in the Wentzville, MO assembly plant?!? I've never heard of an F body car being assembled in this plant. Has anyone else heard of this plant producing Fbodies?
Brad
Brad
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Vin Should be:
1G2FS23??NL2?????
You can find the Plant code in the 11th digit, for all 3rd gens from 1988 thru 1992 the code was "L". Van Nuys California was the only plant to make 3rd gens in 1992. The 1993 model year (4th gen) moved production to St Threse Quebeq Canada in 1992 however.
The Wentsville MO code is a "1" and may have been written wrong, check your vin again.
John
1G2FS23??NL2?????
John
Thanks Okfoz for the reply. A recheck on the VIN number shows we copied the number down. You were correct that this Bird was made in the Van Nuys plant. Thanks for the correction!
Brad
Brad
skinny z
10-05-2015 06:23 PM
Dragonsys
09-25-2015 03:51 PM
