Fog light question for IROC owners (willie??)
I've got a question. On my 85 IROC, my fog lights only operate with the low beams. Others have said that theirs will come on with the parking lamps, but mine will not. Was mine modified (My harness looks fine) or did GM change the operation at some point? My GTA's fogs will come on with the parking lamps, and I'd like my IROC to do that as well.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
My factory foglamps (on my '86) come on with either the parking lamps or the low beams. They shut off when I hit the high beams. As the original owner, I know that this is the way they came.
IROCnRoll
'86 Camaro Sport Coupe and '88 IROC
IROCnRoll
Car: 1987 Z28 Convertible
Transmission: 5-speed
Jim,
Your fog lamps are designed to operate with either the park or low beams on. Disconnect the fog lamp relay and probe for 12 volts at the brown wire that connects to terminal 5 on the relay. It should be marked on the relay. You should see 12 volts when the parking lamps are turned on, as well as the headlamps. This step will help in diagnosing if your wiring has been altered.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig) with 50-hp nitrous: 12.043 @ 112.86 mph.
ATI D1SC (10-psig): 12.056 @ 116.62 mph.
All stats are altitude corrected for 3,100 feet using NHRA's Altitude Correction Table.
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Willie
Thanks guys. Guess I've got another project on the (very long) to-do list.
The IROC Homepage
The IROC Homepage
Hey Jim, The fog lights on my 85 only operate with the low beams too. Seeing as the car is still new at 2,480 original miles, I doubt there's anything wrong with it. Yeah, I know there can be problems on a car of any age or condition but I doubt that it's anything but how GM intended them to work...for 1985 at least.
Cool.
That makes me feel better.
The IROC Homepage
The IROC Homepage
Car: 1990 Formula
Axle/Gears: 3:73 Posi
My buddy has a 87 Iroc-z and his fog lights come on with either the low beams or parking lights.
84 FIREBIRD-(undergoing restoration)2.8 V6,5spd,T-Top
90 Formula Modded 350 TPI T-Top 1/4-13.5@102mph
Picking up next week 87 Firebird 2.8,Auto,T-TOP (Beater Car)
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Previous 3rd gen's
There you have it. Another fact about '85's that I did not know. I owned an '86 (bought it new) and the fog lamps work with both parking and low beams.
Jim, if you want to change the way it works, it's simple to do. Let me know if you do.
Willie
Willie
Thanks for the responses guys. This is pretty much exactly what I wanted to hear.
Willie, I'll let you know if I do decide to change it. I'm going to look at my Helm manual to see what the schematic looks like. I doubt that I'll be fortunate enough to just be able to draw the switch feed from a different wire in the dash. I suspect the fog light switch just feeds a relay that's powered by something from the headlight circuit. I'll find out when I troll the electrical schematics.
The IROC Homepage
The IROC Homepage
Jim,
It's simple to make the change. All you need to do is cut the wire that leads to the #5 connector on the relay. This wire supplies 12 volts with the headlamps on. (The relay is located) on the driver's side inner fenderwell just in front of the fender itself.) Splice into any wire that leads to any of the parking lamps and substitute this wire into the #5 connector. I hesitate to state what color it is for fear that I'll be wrong again!! On my '87, it is brown. This will allow the relay to energize with the parking and headlamps.
Willie
Willie
Thanks willie!
I've got that warm fuzzy feeling from knowing that we both learned a little bit from my experience.
The IROC Homepage
The IROC Homepage
must be 85's only. my friend has an '85 iroc clone --- but it was done to look 100% legit, and it does, except the insurance company has it listed as a SC. and his fogs are headlight only, whereas my '86 iroc is parking and foglights.
Dan Briones
1988 Camaro Sport Coupe
2.8 V6, TCI 3200 Stall TC, B&M Transkit, Flowmaster & Catback
1983 Z/28 CFI Hood, 1989 IROC Foglamps, Custom Painted Tails, 1987 IROC Wheels
Z/28 Grille, "Heritage" Style Stripes, White Face Gauges/Gear Indicator, Homemade DRL's
Dan Briones
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
My 86 IROC fog lamps operate even with park lights off. Done it before just to see how much light those weak XXX things put out, not enough to drive by (unless you're doing 5 mph). There may be something wrong with them (poor ground, loose wire, ??) but since I don't need them I haven't spent time on it yet. Sorry, I should have paid more attention. The park lamps must have been on, but due to the fog they didn't appear to be. Tried it this mornin'. No park lights, no fog lights.
Z's r Best
[This message has been edited by Z's r Best (edited October 18, 2001).]
Z's r Best
<font face="Verdana, Arial" size="2">Originally posted by SlowCamaro88SC:
...except the insurance company has it listed as a SC.
</font>
</font>
My insurance company didn't even ask me about any of that crap. I told them I had a red 85 Chevrolet and that was it.
My GTA on the other hand, was a totally different fiasco. They wanted to know everything about that car.
The IROC Homepage
The IROC Homepage
my insurance company doesn't care what model of motor, all they care is that it's a Chevrolet Camaro, and they charge up the butt for my car to be insured. so it would be good if I was insuring a IROC rather than my SC. they charge you a ton no matter what.
1 Post
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
My '86 Z has the foglights come on with both the parking lights and low beams, off with high beams...
another interesting bit of info, I've noticed some car's lowbeams go off when you turn on the highbeams, others stay on...WTF???My friends '89 is like that...
Hey Jim
My 85 Iroc ,before I change them to after market fog lights would come on with parking lights only, or low beams, or high beams.
I guess I'm different.
Jamieson
2000 NBM TransAm WS6 #485
85 Blue Super Charged Iroc-Z28 Camaro
79 TransAm
1999 Oklahoma Gathering
2000 SWMG
2001 SWMG
Jamieson
79 TransAm
2000 SWMG
2001 SWMG
mustangman65_79
08-11-2015 03:17 PM
