Anybody ever find PRO code "C4B" ?
Only RPO I am missing from my Z. Darn there were a lot of them:
AF9 SEAT, FRT, PASS DRIVER, RECL, OUTSIDE VEND, LEAR DRVR SEAT
AK1 RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLD
AU3 LOCK CONTROL, SIDE DR, ELEC
A01 WINDOW, ALL SHADED, W/S
A31 WINDOW, POWER OPERATED, SIDE
A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RE
BY8 ORNAMENTATION, EXTR FRT DECOR PLATE
B18 ORNAMENTATION, INTR, DELUX
B34 COVERING, FRT FLOOR MATS CARPETED INSERT
B35 COVERING, REAR, FLOOR MATS CARPETED, INSERT
B84 ORNAMENTATION, EXTR MLDG, BODY SIDE, BLK
B9K ORNAMENTATION, B/S MLDG
B91 ORNAMENTATION, EXTR MLDG, DR EDGE GUARD, BLK
B94 ORNAMENTATION, EXTR EMBLEM, BODY, VAR 1
B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
CD4 WIPER SYSTEM WINDSHIELD, PULSE
C4B
C49 DEFOGGER, RR WINDOW, ELECTRIC
C60 HVAC SYSTEM, AIR CONDITIONER, FRT MAN CONTR
C95 LAMP, INTR, ROOF, COURTESY AND DUAL READING
D03 PAINT, PROCESS, WATER BASE
D1C PAINT, HIGH GLOSS
D34 MIRROR I/S, SUN SHADE
D35 MIRROR O/S, LH REM CONT, RH DIRECT CONT, PA
D42 SHADE, RR COMPT SECURITY
D80 SPOILER, RR END PNL
D88 DECAL, STRIPE, SPORT
E5Z SPEEDOMETER ADAPTER (DELETE)
E6E SLEEVE - SPEEDOMETER GEAR
E9Z SPEEDOMETER KEY (DELETE)
GT4 AXLE REAR, 3.73 RATIO
J65 4 WHL DISC BRA
K19 REACTOR SYSTEM, AIR INJECTION
K22 GENERATOR, 94 AMP
K34 CRUISE CONTROL, AUTOMATIC, ELECTRONIC
L69 ENGINE, GAS, 8 CYL, 5.0L, 4BBL, HO
MK6 TRANSMISSION, MAN 5 SPD, BORG WARNER, 2.95
MM5 MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
NA5 EMISSION SYSTEM, FEDERAL, TIER 0
NB1 EMISSION SYSTEM, CLOSED LOOP
N81 TIRES, SPARE, FULL SIZE
NK3 STEERING WHEEL, SPORT, SOFT RIM, SIMULATED
N33 STEERING COLUMN, TILT TYPE
N90 WHEEL, 15X7, ALUMINUM CAST, 4.75 INCH BOLT CIR, SILVER
QYZ TIRE ALL, P215/65 R 15/N BL R/PE ST TL HWY
TR9 LAMP, GROUP
TT5 HEADLAMPS, HALOGEN, 2
T63 ALARM, HEADLAMPS ON WARNING SYSTEM
T93 LAMP, TAIL & STOP, SPECIAL
UA1 HD BATTERY
U05 HORN, DUAL
U21 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 LAMP, INTR, RR COMPT, COURTESY
U26 LAMP, INTR, ENG COMPT, COURTESY
U29 LAMP, INTR I/P, COURTESY
U35 CLOCK, QUARTZ, ELECTRIC
VAN VAN NUYS CA ASSEMBLY PLANT
V73 VEHICLE STATEMENT, US/CANADA
YS1 REAR SEAT, CUSTOM TRIM
YT2 BUILD UP DR & QTR, CUSTOM
YT9 FISHER FURNISHED PARTS
Y06 CPT K/PAD, PANEL,COWL KICK(CARPETED)
ZK1 HOOD INSULATO
Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
1AZ ORDER MODIFICATION ORDERS SOLD(THAT THE VEHICLE WAS BUILT SPECIAL FOR SOMEONE AS OPPOSED TO A DEALER WHO ORDERED IT FOR THE LOT)
16P WHEEL COLOR, SILVER
22A BLUE STRIPE
22D TRIM COMBINATION, CLOTH, DK ROYAL BLUE (D)
22I BLUE TRIM
229 SEAT BELT COLOR, (DARK ROYAL BLUE)
27L EXTERIOR COLOR, SECONDARY (MED. DARK ROYAL BLUE)
27U EXTERIOR COLOR, PRIMARY (MED. DARK ROYAL BLUE)
6ZX SPRING, COMPUTER SELECTED, FRONT, LH
7ZX SPRING, COMPUTER SELECTED, FRONT, RH
8NN SPRING, COMPUTER SELECTED, REAR, LH
9NN SPRING, COMPUTER SELECTED, REAR, RH
1984 L69 5-speed Z28, T-tops, Polished Irocs, Dynomax headers, Flowmaster exhaust, 14.87 in the quarter. Currently 50,370 original miles.
C4B
J65 4 WHL DISC BRA
TR9 LAMP, GROUP
UA1 HD BATTERY
U05 HORN, DUAL
ZK1 HOOD INSULATO
22A BLUE STRIPE
22I BLUE TRIM
Well, the numbers on my block are as follows:
V1020SUH
Which breaks down as follows:
V FLINT (ENGINE) ASSEMBLY PLANT
10 MONTH MONTH OF MANUFACTURE
20 DAY DAY OF MANUFACTURE
SUH 8 CYL, 305 CID, 190 HP, 9.5:1 COMP RATIO, 4BC, MAN TRANS DESCRIPTION
V1020SUH
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
