Why can't I find the correct paint for my car
Car: 89 Camaro RS Convertible
Transmission: NWC T-5
Does anyone else have WA 9636 for their car? I'm having the hardest time finding paint for my car. Some think its medium gray, others say its gunmetal. I tell them to shove it and give me the correct paint not what they think it is.
I have bought it before but the place I normally go to doesn't have it anymore. The last can I got says gunmetal but its specific to the paint code unlike the other gunmetal shades.
Any one know of a place in the Pa area, or anywhere that will ship it to my house where that paint is available?
Thanks in advance
Phil
Thanks in advance
Phil
Bring the paint code to any auto parts store that can mix paint, or to any body shop that mixes paint and you'll have your color.
Your paint code should be a 3 digit code.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Oops my bad. I was so pissed off, that I did type it wrong. It is wa 9536 which is a shade of gray. The auto paint store no longer has the cross reference with the paint code so I can't get it mixed. Its the only one in the area I live in that can do it.
Anyone have the correct mixture for the color? Then I can take it to them and see how it comes out.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Is there a Sherwin Williams in town?? They can make mine...
And FYI, the color IS Medium Gray Metallic...I think I would know
Jason E
'89 Camaro RS
Medium Grey Metallic
2.8, A4, T-tops, 91k miles, a few bolt ons
Alpine 60x4 and Bostons
'97 Z28
30th Anniversary package (white with orange stripes)
LT1, M6, t-tops, 42k miles
Eclipse CD and 10" Aluminum sub in JL Audio Stealth box, Boston RM speakers, Xtant 403a amp
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Jason E
'89 Camaro RS
'97 Z28
Long Live #3...
Thank you everyone for your help. At least I know what color I want and that this code exists.
Next question, any other Camaro owners with that WA # in there RPO sheet? I mean, the Camaro White Book I have only lists Medium Gray as a color and not Gunmetal. I always thought its was only a color on Firebirds only.
Interresting. I always thought the paint codes were 3 digit codes.
Guess I'll have to go consult the old white book.
The IROC Homepage
The IROC Homepage
I believe 85 or 86 and below is a 3 digit WA. Anything afterward is a 4 digit. I remember doing a lot of cross referencing and I saw in either 85 or 86 the way paint codes were made changed.
<font face="Verdana, Arial" size="2">Originally posted by 89RagTopRS:
I believe 85 or 86 and below is a 3 digit WA. Anything afterward is a 4 digit. I remember doing a lot of cross referencing and I saw in either 85 or 86 the way paint codes were made changed.</font>
I don't remember the exact year they changed but I remember glancing through the GM book and it says such a year and below and then such a year-present
Member of the Jersey F-body Association (JFA)
1989 Camaro Convertible RS
dark silver w/black top
305tbi, auto, 3.73 posi
SLP exhaust, 16x8 black GTA Crosslace Rims
Check out Phil's Rice Boy Page
So were there two grays in '89, or is Gunmetal the same as Medium?? My window sticker says Medium...
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I take it that the lower paint code doesn't refer to the color of the ground effects? My upper and lower paint codes are the same, but my gfx are dark grey.
Medium gray is darker than Gunmetal as I just found out. I had to paint my spoiler in Medium Gray and its darker than my gunmetal paintjob.
Engine: 383 Carb
Transmission: 4L60
<font face="Verdana, Arial" size="2">Originally posted by 82RECAROTA:
Do you have any other RPO that is two numbers and a letter? On your cowl tag do you have 15L 15U xxx? What is xxx?</font>
Engine: 383 Carb
Transmission: 4L60
Engine: 383 Carb
Transmission: 4L60
My entire cowl tag is:
<PRE><FONT SIZE=+2>
E 03E 1FP87 L 183737
15L 15U WATER
17C AR9 R
D S 293933
</PRE><FONT SIZE=-1>
There are no WWx codes on the RPO sticker.
[This message has been edited by Apeiron (edited July 19, 2001).]
<PRE><FONT SIZE=+2>
15L 15U WATER
17C AR9 R
D S 293933
Engine: 383 Carb
Transmission: 4L60
It's a Z28, it came with ground effects.
B97 - Ornamentation, Extr Mldg, Lower Accent
Car: 86 T/A
Engine: 5.0 TPI
www.paintscratch.com
....OUTRAGEOUS. $29.95 a spray can. Our local paint store custom mixes and puts in a can for $9.95.
If Medium Gray is darker, then here is something interesting...
My car was dealer-repainted in 1990 under factory warranty, due to the typical GM clearcoat peel, and there was a HAIR stuck in the hood from the factory...
Anyways, when it came back, it was notably darker than before! You can see the masking lip on the inside of the doorjambs...the new paint is noticeably darker than the factory job. I always assumed the dealer mixed it wrong, or they used the wrong GM gray...
Not to start a fight, but is it possible Gunmetal Gray was darker? I ask solely because mine was Medium, was repainted by a dealer, and came out darker. The only reason I really even care is because when I repaint it next Spring (the dealer clearcoat is peeling in a few spots, and I'm a perfectionist ), I WANT the darker color...my mom and dad thought it looked great when it came back, and I have seen other gray F bodies, and always liked mine better!
If anyone has any idea, let me know...
medium gray paint can differ up to 10 shades. To be called med. gray, it can be 5 shades darker or lighter if it is to replace factory spec paint.
Trust me gunmetal is lighter. I have a couple of empty cans of paint from earlier painting I did to the car. Its the same WA as on my RPO. I was looking for about 12 ounces to paint my spoiler but I had to settle with med. gray which came out a lot darker than the gunmetal, both the factory paint still on it and what I did.
If you looking for a dark gray, don't really look at F-body cars for that. They only had 2 grays and aparently gunmetal is exceptionally unusual.
Linson
08-21-2015 02:12 PM
kah992
08-19-2015 02:55 PM
