Need Front Strut part number from 1987 Trans Am
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Need OEM Front Strut part number from an original 1987 Trans Am
Does anyone still own a 1987 Trans Am with the stock front struts? I need to verify the part numbers.
The ones on my cars are strange and I need something to compare to.
Need strut numbers for
- 1987 Trans Am WS6
- 1988 Trans Am WS6
I would think a IROC would work as well.
Strangely enough a IROC Vert might be what I am looking for as these may have been the base valving used for the racing struts.
Mark.
- 1987 Trans Am WS6
- 1988 Trans Am WS6
Mark.
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
The GM Part # for the front strut is 22064184- I don't know if these are still available from the dealer or not- they don't show up on GMpartsdirect.com
Engine: TPI(s)
Is that the number that would be stamped on the lower tube of the strut?
I have some really strange numbers on mine, but I sort of expected it. I am trying to sort out what it means and was hoping it was close to the stock number at least in form.
I'll have to post a picture.
Mark.
Mark.
Engine: TPI(s)
Here is the number and letters that appear on my 87 TA:
line1: 71728E
line2: MADE IN THE U.S.A.
line3: H255001A
My 88TA is similar with
line1: 728
line3: H26491A
Both cars came with "special" struts for the racing series. These were pre-1LE cars, hence these were the struts that led to the production 1LE ones.
IF I knew who the OEM was, it might help. I assume they are Delco parts.
line1: 71728E
line3: H255001A
line1: 728
line3: H26491A
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
From the Parts & Illustration Catalog-
Strut (1987-1988)(1989-1990 FE1)....10027257
Strut 91-92 (F41) 22047999
Strut 91-92 (LHO) 22035663
Strut 91-92 (LO3 FE1) 22064122
Strut 91-92 (FE2 (EXEC 1LE) 22064121
Strut 91-92 (1LE) 22064153
Hope that helps.
John
Hope that helps.
John
THis is from the Parts list, it seems to be more complete
82-84 (EXC WS6,WS7,WY5, WY6 )......................... 22035663
85 (EXC WS6)......................................................... 22035663
85-86 PERF PKG (WS6) .......................................... 22064121
86 (2.5-2, 2.8-S) .................................................... 22035663
87-88 (EXC RIDE & HANDLING FE2, H.D. SUSP F41) 22047972
87 W/TOURING SUSP (FE2)..................................... 22064121
88 (2.8S) H.D. SUSP (F41)....................................... 22047972
88 (5.0E,F) H.D. SUSP (F41).................................... 22047999
89 (2.8S)................................................................. 22035663
89-90 SOFT RIDE SUSP (FE1).................................. 22047972
89-92 FIRM RIDE & HANDLING SUSP (F41).............. 22047999
89 F87 (5.0E) SOFT RIDE (FE1)............................... 22064122
90-92 3.1T (LHO) ................................................... 22035663
90-92 5.0E(LO3), SOFT RIDE SUSP (FE1)................ 22064122
91-92 RIDE & HANDLING SUSP (FE2) (EXC 1LE)...... 22064121
91-92 (1LE)............................................................. 22064153
John
John
Engine: TPI(s)
Thanks for the info.
Interesting. At least those numbers make sense.
Any idea where the 89 1LE is? I recall it used a deflective disc which was discontinued shortly after.
My 87/88 struts are still a mystery. Obviously race-only substitutions. I have a lead on the part numbers as they appear to be "Tokico".
http://www.tokicogasshocks.com/
Mark.
Mark.
1992 Trans Am
05-10-2023 07:19 PM
beachrodder
08-25-2015 08:05 AM
