Can You ID This Firebird by the VIN?
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I found a car for sale but don't know the RPO codes.
The owner claims it is a WS6 Firebird. The VIN is
1G2FS21F4KL242766
Can you tell from the VIN if it is a TA or Formula? I'm a Camaro guy. I don't know anythinkg about firebirds but it looks like this car might be a good deal.
Thanks.
1G2FS21F4KL242766
Thanks.
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
If I am reading the VIN correctly, it looks like a 1989 Formula. The S indicates Firebird but the engine code is F, which was the tuned port injected version of the 305 which was not available on the base model Firebird, but was available on the Formula. So from what I see, it looks like a 1989 Formula.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
YES IT HAS WS6
John
John
tom1985
04-19-2016 07:55 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
