More RPO Codes-N03 and YT9??
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
I recently found my RPO code sheet that used to be in my center console...and i researched all the codes from the RPO decoder, but found 2 that dont add up. N03 and YT9 are not on this board's database..anyone know or have a clue as to what this is?? Also, I have the LB9 engine..305 Tuned Port...but on my side ground effects, it says "5.0 Liter FI"....that stands for fuel injection, right? But i have seen TA's with "5.0 Liter H.O." written instead...which is correct? Something screwey about my car? Any help would be appreciated...thankx.
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
[This message has been edited by PhantomTPI (edited May 17, 2001).]
OTHER RIDE:
12/14 Options
Stock(for now)
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Engine: 5.0 TPI
Ok good...thats what i figured. Thank you. Anyone else have any idea what NO3 and YT9 are in terms of RPO codes?
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
Engine: 5.0 TPI
AMEN!!
Thank you for that, Mike....I appreciate it. Just one more...the NO3 code....anyone??
OTHER RIDE:
12/14 Options
Stock(for now)
![](https://www.thirdgen.org/messgboard/biggrin.gif)
OTHER RIDE:
12/14 Options
Stock(for now)
Engine: 5.0 TPI
Ok, now realizing what a dumbs**t i really am, i mis-spelled the code. I read it wrong off my RPO sheet...yes folks, i am sorry for wasting your time....however, not all time is wasted...the code that STILL does not come up on the RPO decoder on this board, is NOD or N0D...cannot decode this RPO code...its NOT NO3 or N03....sorry about that...i have an assload of codes, and i guess mixed/matched them...my fault...any help please?
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
If its NOD that could mean the car was built in Norwood, Ohio. VAN means Van Nuys, California.
I might be wrong. I cant remember if Norwood, Ohio is NOR or NOD.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Engine: 5.0 TPI
Thanks Kevin...but why would something like that appear on the RPO option code sheet that was in my center console? I thought something like that would only show up on a VIN number.
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
Engine: 5.0 TPI
I havent raced it since i put the high-flow cat and flowmaster on it, but with a completely clogged, hole-riddled and rusted exhaust system(before i changed it) it ran consistent 15.9 1/4ths. I am sure it can do better now.
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
<font face="Verdana, Arial" size="2">Originally posted by PhantomTPI:
</font>
</font>
Engine: 5.0 TPI
Well, you must be right then...I cant come up with another possible explanation that actually makes sense. Thanks for your help.
OTHER RIDE:
12/14 Options
Stock(for now)
OTHER RIDE:
12/14 Options
Stock(for now)
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
