What is a rear cargo cover? Is it factory?
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hello
My rpo codes say i had a rear cargo cover. Whatever it is i no longer have it. What does thins think look like? Is it one of those roll up shades for the rear hatch? Or is it the hard well cover folding plate?
Thank u
speed
Thank u
speed
Received 1,839 Likes
It is the window shade thing.
If it's in your RPO codes, you probably have the mounts for it; 2 round plastic things that look like 2" diameter giant slot-head screws, right over the rear wheel housings.
Yes they were factory.
Car: 1989 IROC-Z
Engine: 346 LS6
Yes they are two black circle things.
But then what is that hard cover for the trunk well?...Is that a factory thing?
Speed
Speed
Transmission: TH200C....700R4
Speed
Speed
Yes it also is factory.
I forget what it's called, I guess I'll have to go look at my factory invoice, and get its "official" name. My car came with both things.
RPO D42 Rear Window Shade is the roll up curtain that is inserted into the black plastic round mounts and hooks onto the glass hatch. Early cars got a one made of vinyl while later cars had a cloth curtain. I'm not exactly sure when the change was but its around 1988 or 1989.
RPO B27 Rear Cargo Trim included carpet on the rear trunk interior side panels and the lockable storage well cover. Camaros with the BOSE stereo option also got the storage well cover but with intergrated speakers.
Car: 1989 IROC-Z
Engine: 346 LS6
Yes I have D42 [had] thats what my RPo says
Is it something useful or is a peice of garbage that gets in your way?
Also would mine have been medium grey like my interior or are they all black or something?
Speed
Speed
Car: 1989 IROC-Z
Engine: 346 LS6
I mean like does the cloth fade alot worse than the leatherette or does the leatherette crack and cloth is the way to go?
Speed
Speed
Couldn't tell you how the vinyl ages, all my cars that have them have canvas, and yes they fade. Purple-ish brown or gray depending on how the light hits em. The only time you can really tell is if you pull it out further then it normally is extended in the closed position, which exposes the material that normally is shielded from UV.
1 Post
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
The canvas ones are easy to dye though and will look good afterwords.
1992 Trans Am
05-10-2023 07:19 PM
I'llrocya
02-02-2016 11:43 PM
