G92 Question
sure they did. Z28 only ...4703
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC
when it warms up Edelbrock STB maybe springs
Jeremy
92 Z conv
5-spd B&M shifter
The G92 option in 1986 was available on the Z28 with the LB9 305 T.P.I. only. the content of the option was just a lower gear ratio. When you ordered the TPI in the Z28 you got the 2.73 standard, the G92 option bumped the ratio up to 3.23 Chris
