Greek number in 8th digit of vin?
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
Looked like an 8, but it wasn't an 8. Sort of like a half circle for the bottom part of an 8.
It was a plain looking Firebird (Not a Formula), I've been looking around, and it looked very strange :S
Car: 1987 IROC-Z
Engine: 5.7L V8
Transmission: TH700R4
Axle/Gears: 3.73 Borg Warner
Run it through CarFAX or something with an 8 in the digit and see if it comes back. Or, find another place on the car where the VIN is listed and check that. If shows as an 8, then it was probably just a screwup when they stamped the VIN plate.
Car: 95 Camaro Z28
Axle/Gears: 3.23s
A part of the rear was really rotted. I walked away.
I'm asking because I thought it was strange.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Base firebirds could get an S with the V6, not sure about other years but for 87-89 for sure.
JOHn
JOHn
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
'86s had an S for the 2.8 MPFI, I believe that '85s did also since they were MPFIs as well, same bumpers just different taillights.
Car: 87 Formula 350 / 89 Firebird
Engine: L98 / 2.8 V6
Transmission: 700r4 / 700r4
Axle/Gears: 9 Bolt 3.27 / 10 Bolt 3.42
You were probrably looking at the 9th digit actually. I just did the same thing not too long ago when i was looking at a parts car 88 Iroc. Looks like an odd looking 8 with a flat top, but was in the 9th digit. Made me think i was looking at a factory L98 car for $300 complete .
3.8TransAM
09-27-2015 08:37 PM
