84 Trans Am H.O.
There were about 55,000 84 Trans Ams (LG4 & L69). The 5 speed cars are more rare than the automatics. Also the L69's (H.O.) are more rare than then LG4s. There was also a 1500 run of 15th Anniversary T/A's. Most white/blue combos with white Recaro seats. Some traditional black and gold combos were also made. Along with just "plain" Recaro Trans Ams. I think you're shooting for if it is a rare car....it's not as "rare" as some other thirdgens (92 GTA's come to mind) but the numbers of 84 Trans Ams are dwindling, most becoming parts cars. 84 Trans Ams are very identifable, the nose is 84 specific, so are the stock W62 Aero effect option ground effects (Also a hard find if you're in need of them). Some 84 T/As come with functional (L69 only?)"turbo-blister" style hoods and most have the hood but non-functional set-up. Another rare option was turbo-finned aluminum rims with firebird spinners.
'84 Trans Am
Crate 350 - 4 bolt main, Holley 600 w/vac. secondaries now open element
T-5 - Stock with Zoom clutch and PP
'84 Trans Am
Car: 1984 Trans Am
Engine: GMPP 350 V8
The blister on my 84 LG4 is functional. The blister on my 83 T/A LG4 was functional too (before the cowl hood).
83 T/A 84 T/A 94 25th anniv. T/A and some Fords.
Oh, ok. I didn't know for sure because I've seen two '84 T/A's that claimed to be stock, had the LG4, and the blister hood but it didn't have the connection to the aircleaner.
'84 Trans Am
'84 Trans Am
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
My girlfriend actually has an 84 T/A with the L69, 700R-4 and 3.73 rear end. Damn thing has like 140,000 miles on it and it still runs pretty good.
1989 IROCZ28, 5.7 liter TPI, 700R-4, 2.77 Rear, Gutted Air Boxes, Clarion 8575 Head, Infintiy Kappa 4x6 plates, Stock 6x9's, Alumapro 10" Aluminum Sub in sealed box, Orion 400 watt amp
So does anyone know if the black and gold combo is rare or more rare than other 84s? My car has the black and gold, the ground effects are only in front of the wheel wells, and it has the functional cowl hood. Also, would anyone know why the car wouldn't have a radio from the factory? T-tops, A/C, all wheel discs, and no radio.
the 84 nose was only specific in trans am form , base firebird was the same as the 82 and 83, 15th anniverssary were only white with the blue trim and thast the onle color the anniversary cars came in ,
Car: 1984 Trans Am
Engine: GMPP 350 V8
My 84 is Blue w/ silver decals and GFX. T-tops, discs, a/c and radio. (along w/ other stuff). I have seen pictures of Black and Gold 84's, so they are out there.
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I have all of the production specs including the original dealership sales literature for the 84's at home. I'll see about bringing in the specs and placing them on the web site.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Daniel Burk
I'llrocya
02-02-2016 11:43 PM
