T Top Outer Seal Question
Car: 89 Iroc Convertible
Recently at the junkyard I was pulling off the outer strip seals from a pair of t tops on a 1991 trans am. The drivers side t top was broken and just had the outer edge with the flexable type strip but the passengers side was made of hard plastic and not the usual flexable material.It has a gm part# of 10165498.I was wondering if these plastic type strips were used on all the Lexan T Tops as I have not seen them before
Engine: 4++,350 & 305 CIs
I think but am not sure but GM started using them around 91..
I do know that 9 yrs ago when i painted my car i put in new seals from GM and the kit came with those hard plastic ones.. and I also parted out a 91 305 TPI auto leather 2.73 aluminum drum brake Lexan TTOP GTA that the plastic drip rail was there ...
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It was in either 1991, but more than likely I think they may hve started the newer drip rails in 1989, apparently thats when they updated the T-top seals. Whenever they did the change Both the Glass T-tops and the Acrylic T-tops got the new plastic piece.
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
