1984 TA Shifter question
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
I was wondering if the shift indicator light on 1984 Firebird's/TA's was backlit red. I thought that all the instrumentation, gagues, radio, heater controls, was backlit red including the shift indicator light. I saw an '84 at the junkyard and took off the shift plate but the housing the bulb would connect to was white, and the inside wasn't the orange color the gauges and heater controls are. Are these susposed to be backlit red or what??
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
afaik theyre all white
but you can change it to whatever you color you want by painting or buying a colored bulb.,.
hope that helps
hope that helps
Car: 1982 Trans Am
Engine: SBC 400
was that the shift indicator light? I know the gauges and heater controls were redish orange as I have them and they are painted an orange color as opposed to white on earlier TA's. Since the backs of the gauges were orange and the back of the bezel was orange the lights would reflect this color. All the bulbs were regular "white" changing the color bulb does not have the same effect with regular gauges.
The only reason I'm asking is because the '84 I looked at didn't seem to have a red/orange colored light housing for the shift bezel.
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The shift indicators were the normal orange/red as the dash gages and heater controlled on 1984s.
The light housing is orange as well as part of the PR(D)D21 indicator plate.
The bulbs have always been clear.
colton_carlson
03-08-2019 12:21 PM
84z96L31vortec
08-20-2017 12:16 AM
