Did they make 1984 Trans Am's w/o GFX??
Old 11-21-2005 | 01:03 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i was talking to a fellow TGOer about my car and he said that because my car doesnt have GFX it isn't a trans am....Is this true??
here are my RPO codes....
AAA : 4-WAY MANUAL SEAT ADJUSTER
AM9 : SEAT, RR, SPLIT, BACK, FLDG
AU3 : LOCK CONTROL, SIDE DR, ELEC
A01 : WINDOW, TINTED, ALL SHADED, W/S
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BV8 : ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER,
B20 : ORNAMENTATION, INTR, LUXURY
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D03 : PAINT, PROCESS, WATER BASE
D1T : GEAR, SPEEDO DRIVEN
D35 : MIRROR, OUTSIDE REAR VIEW
D42 : SHADE, RR COMPT SECURITY
D53 : ORNAMENTATION, EXTR HWD APPLIOUE
D80 : SPOILER, RR END PNL
E5Z : SPEEDOMETER ADAPTER (DELETE)
GT4 : AXLE REAR, 3.73 RATIO
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
K19 : REACTOR SYSTEM, AIR INJECTION
K22 : GENERATOR, 94 AMP
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
L69 : ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
Unable to locate code MX0 in our database!
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NB1 : EMISSION SYSTEM, CLOSED LOOP
N33 : STEERING COLUMN, TILT TYPE
N78 : WHEEL, I4 X 6, ALUMINUM, HUB CAP, WHEEL NUTS
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
TR9 : LAMP, GROUP
T93 : LAMP, TAIL & STOP, SPECIAL
UA1 : BATTERY, HEAVY DUTY
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
UT1 : TONE GENERATOR, WARNING
UU7 : RADIO, AM/FM STEREO, CASS, CLOCK ETR
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U23 : CLUSTER, INST, TRIM ODOM
U25 : LAMP, INTR, RR COMPT, COURTESY
U27 : LAMP, INTR, I/P COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U73 : ANTENNA, FIXED, RADIO
U81 : SPEAKER SYSTEM, RR, DUAL
VAN : ASSEMBLY PLANT, VAN NUYS, CA
V73 : ANTENNA, FIXED
Unable to locate code WS3 in our database!
WS4 : MODEL CONVERSION, TRANS AM
Unable to locate code WY6 in our database!
YR1 : SEAT,FRT CUSTOM
YS1 : SEAT,RR CUST
YT1 : BUILD UP DR & QTR
YT9 : ???
179 : SEAT BELT, COLOR CHARCOAL (91)
Unable to locate code 19M in our database!
Unable to locate code 6ZM in our database!
Unable to locate code 7ZM in our database!
8NM : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
84P : WHEEL COLOR GRAY (91)
9NM : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
isn't the WS3 code the WS6 code for my year??? or what else could it be for that year cuz i heard that it was called something else in that year....
but if my car is a trans am....is it a rare one because it didnt come with GFX???
another thing....if it weren't a trans am would it be considered a formula??? i thought those weren't reintroduced until like 87 or so......
Old 11-21-2005 | 02:25 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Tell your friend he is full of doggie doo doo.
The RPO W62 "Aero Package" ground effects were optional on 1984 Trans Ams. They are not standard (unless you bought a Recaro or 15th Aniversary T/A)
I would say a lot of owners did opt for the aero package in 1984 but there was still plenty that didn't have it. Either way is certainly not going to affect the value of the car any.
I've never heard of WS3. I don't recall seeing that code on the SPID label on the console door in '84 T/A and its not on the build sheet I found under one of the rear seats.
WS4 is the RPO code for Trans Am.
WS6 is a performance suspension option which included larger sway bars, stiffer springs, bushings, shocks, 12.7:1 ratio steering box, 15x7 rims, 4-wheel-disc brakes, and posi-traction rear axle. Your car has the oddball WY6 option which included all the WS6 goodies except the posi-traction. I would guess that the factory was having shortages of posi-traction units and came up with WY6 to keep production moving.
Old 11-21-2005 | 09:19 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Not wishing to hi-jack the thread, but what exactly did the "aero package" consist of?
Old 11-21-2005 | 12:39 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
-WS1 is "Firebird Performance value package #1"
-WS2 is unknown
-WS3 is "Firebird Performance value package #2"
-WS4 is Trans Am package
-WS5 is unknown
-WS6 is performance suspension package 82-92
-WS7 is another special performance package (same as WS6 but with drum brakes before 1985.) Later on it was the Users Manual - starting in the mid 90's
-WS8 is "Priced order acknowledged" whatever that means. Might have to do with ordering a car.
-WS9 is taken its the RPO for the Formula package according to thirdgen RPO decoder.
YT9 - Porbably tires
IIRC The "Aero Package" in 1983 & 1984 was simply ground fx, starting in 1987 it also included the wrap around spoiler on the Trans Am, thus "Aero spoiler" . In 1985 & 86 the spoiler was available but not a part of the package until 1987. In 1986 the spoiler was deletable to the base wing for credit. In 1989 - 1992 the Base firebird could get an Aero Package that was the same as the Trans Am, But it did not get the aero Spoiler or the T/A hood or fenders.
I hope that helps.
John
Old 11-21-2005 | 01:00 PM
okfoz's Avatar
MX0 try MXO - Automatic trans
19M - Black Something... Probably an interior trim piece. 19 = Black
6ZM
7ZM
On a long shot, the Rpos with a number then a Z are he following:
1Z? thru 4Z? = Nothing
5Z1 = Oil Pan 5 quart
5Z4 = Spare tire and wheel DELETE
5Z5 = Hubcaps DELETE
5Z9 = Radio Antenna DELETE
6Z? - Nothing
7Z1 = Horn Dual, High note
7Z5 = Circuit Breakers, Additional 12 Volt
7Z7 = Cluster Kilo - Leaded Fuel
7Z9 = Cluster Poliece - telltale
8Z1 = Engine DELETE ( I want this one )
8Z2 = Transmission DELETE
8Z3 = Generator 100 Amp heavy duity Penske/Ryder
8Z5 = Cap Metal Valve stem
John
Old 11-21-2005 | 01:09 PM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
I hope that helps.
John [/B]
Yep it does, thanks.
Old 11-21-2005 | 06:06 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
matt, it has the gfx piece just in front of theback wheel doesnt it ? i cant tell in your pics for sure but i think i saw it one of the pics
this was the only GFX that the t/a could have in pre-85 afaik
mine is identical to yours
nice ride
Old 11-21-2005 | 07:18 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yes it just has that little lip or whatever you wanna call it....
Old 11-22-2005 | 07:26 AM
okfoz's Avatar
I believe its called a "Wheel well Spat"
John
Old 11-22-2005 | 11:16 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
spat, hehee
well sounds like a regular normal trans am exterior to me
i see nothing on the outside that it is missing that a trans am that year would have
is that hood a bulge one ? of course thats a dumb Q on my part, sinc ei see its an L69
hell my LG4 got power bulge even
very common hood
good luck
Old 11-22-2005 | 01:01 PM
Dens71TA's Avatar
Originally posted by Fast68
spat, hehee
Real dumb because the power bulge hood was only optional on the LG4 Trans Am in 1982. We're talking about a 1984 Trans Am.
Old 11-22-2005 | 01:23 PM
Dens71TA's Avatar
Ok, I made up a picture that shows the two different options.
The B97 Wheel Spoiler was standard on regular 1982-1984 Trans Am and 1982-83 Recaro T/A.
The W62 Aero package was standard on 1983 Daytona Pace Car T/A, 1984 Recaro T/A, and 1984 15th Aniversary T/A. It was optional on regular 1984 Trans Am.
Attached Thumbnails Did they make 1984 Trans Am's w/o GFX??-8284grdefx.jpg
Old 11-22-2005 | 05:12 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
My 84 T/A doesnt have GFX....(luckily).
Old 11-22-2005 | 10:19 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah...not to knock the 82-84's with gfx but i am really glad mine doesnt either.......
Old 11-23-2005 | 07:06 PM
84L69TA's Avatar
Car: 4 Mopars total
I hate GFX.
Old 11-30-2005 | 08:29 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
lol....
Jorlain
08-24-2022 05:11 PM
colton_carlson
03-08-2019 12:21 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
Reddeath210
10-06-2015 08:20 AM
Exxon Limited
08-09-2015 08:13 PM
Quick Reply: Did they make 1984 Trans Am's w/o GFX??
