My new car
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
My new car
I just picked this car up today. I like it and my dad thinks I should restore it and that's very wierd for him to offer help. So It must be somthing special. lol. But I just wan't your guys opion on what to do. I don't plain on leveing much stock. And it's in great condition right now. It has almost all the stuff it was supose to come with. I'm just missing little stuff like the spare and floor mats. So I might restore it.
So here is what I found out about it sofar. I just have the one problem with the last rpo code P2P. I can't figure it out. Thanks for the help guys! Adam :-)
1987 Chevrolet Camaro Z28:
1G1FP2180HL141658
Third Generation (1982 - 1992)
17 digit VIN Breakout
Digit
Loc. Code
Description
1st Country 1 USA
2nd Manufacturer G General Motors
3rd Make 1 Chevrolet
4th Carline Code F F-Body
5th Series P Camaro (All Models)
6th Body Type 2 2-Door Hatchback Coupe
7th Restraint Syst. 1 Manual seatbelts
8th Engine 8 B2L/L98 V8 350-cid Engine
9th Check Digit 0 VALID - Your VIN Appears to be CORRECT. Your VIN's Check Digit: 0 Computed Check Digit: 0
10th Year H 1987
11th Factory L Van Nuys, California
12th - 17th Seq. Prod # 141658 141658
RPO Description
AC3 ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9 ADJUSTER, SEAT, POWER, 6 WAY
AM9 SEAT, RR, SPLIT, BACK, FLDG
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AV3 HOOK, CARGO TIE DOWN
A01 WINDOW, TINTED, ALL SHADED, W/S
A31 WINDOW, POWER OPERATED, ALL DOORS
A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B18 ORNAMENTATION, INTR, DELUX
B2L PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
B3W ADVANCEND PRICE SHEET PROCESSING OPTION
B34 COVERING, FRONT, FLOOR MATS, CARPETED INSERT
B35 COVERING, REAR, FLOOR MATS, CARPETED INSERT
B4Z IROC PACKAGE
B48 TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B94 FENDER EMBLEM, Z28
B94 ORNAMENTATION, EXTR EMBLEM, BODY, VAR 1
B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
CD4 WIPER SYSTEM WINDSHIELD, PULSE
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DD8 MIRROR I/S, R/V, LT SENSITIVE
DE1 SUNSHADE, BACK WINDOW
DG7 MIRROR O/S, LH & RH, REM CONT, ELEC, PAINTED
DK6 CONSOLE ROOF, INTERIOR
D08 PAINT, HIGH GLOSS FINISH
D27 COVER, RR COMPT, TRUNK STOW
D34 MIRROR, VISOR VANITY
D6M GEAR, SPEEDO DRIVEN
D80 SPOILER, RR END PNL
D88 DECAL, STRIPE, SPORT
E5Z SPEEDOMETER ADAPTER (DELETE)
FE2 SUSPENSION SYSTEM, RIDE HANDLING
GW6 AXLE REAR, 3.27 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
J65 BRAKE SYSTEM, PWR, FRT & RR DISC
KC4 COOLING SYSTEM, HEAVY DUTY ENGINE OIL
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 GENERATOR,105 AMP
L98 5.7-LITER V8 TPI ENGINE
MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0 MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NP5 LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N33 STEERING COLUMN, TILT TYPE
N64 WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
N96 WHEEL, 16 X 8, CAST ALUMINUM
PB4 LOCK CONTROL, WHEEL
P20 HUBCAPS, WHEEL, STYLED
QDZ TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9 LAMP, GROUP
TT4 HEADLAMPS, HALOGEN, 4
T93 LAMP, TAIL & STOP, SPECIAL or TAIL & STOP LAMP, SMOKED
T96 FOG LAMPS - FRONT
UQ1 RADIO PROVISIONS, FOR STEREO
UQ4 SPEAKER SYSTEM, BOSE, 4
UU8 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
U21 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 LAMP, INTR, RR COMPT, COURTESY
U26 LAMP, INTR, ENG COMPT, COURTESY
U29 LAMP, INTR I/P, COURTESY
VAN ASSEMBLY PLANT, VAN NUYS, CA
V73 ANTENNA, FIXED
YR1 SEAT,FRT CUSTOM
YS1 SEAT,RR CUST
YT1 BUILD UP DR & QTR
YT9 OPTION PACKAGE, FISHER FURNISHED PARTS
Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR)
1HV COMPONENTS OF THE IROC-Z PACKAGE
1SC OPTION PACKAGE 03
19Q MOLDING COLOR (BLACK)
41U PRIMARY COLOR, EXTERIOR, BLACK
6ZX SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
62I INTERIOR TRIM, LT SADDLE (I)
622 TRIM COMBINATION, LEATHER, LT SADDLE (2)
7ZX SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL SPRING, COMPUTER SELECTED, REAR, LEFT HAND
88A STRIPE COLOR, ACCENT, TWO TONE, GOLD/BLACK (91)
9NL SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
P2P ?
1G1FP2180HL141658
Digit
Loc. Code
Description
1st Country 1 USA
10th Year H 1987
RPO Description
B4Z IROC PACKAGE
TR9 LAMP, GROUP
V73 ANTENNA, FIXED
YR1 SEAT,FRT CUSTOM
YS1 SEAT,RR CUST
P2P ?
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You couldn't in 90-92, but in 87-89 it was available. In 90-92 the only cars that t-tops were only available that had a 350 were in the Formula 350's
From what I was told is that gm told the dealers to try and not offer them like that. Do to the added stress on the frame from the 350. They wanted to be more safe then sorry, if they had to recall them. But if you complained enough they would give it to you or if you knew a dealer that was loose with the rules. Adam :-)
I really didn't care if t- tops are rare with the l98. I'm just glad I have them again. You don't relize how much you miss them till you don't have them. The one thing I find wierd with this car tough, is even with it pretty much being fully loaded. I still don't have a bloody rear window defroster! lol. I mean come on. Even the bare bone cars have it. lol. I do know thats one thing thats going to be added to this car. Adam :-)
P.S. So know one knows what the heck the RPO code P2P is.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Actually for the Firebird line the T-tops and a 350 was not available according to the dealer order sheet in 1987. As it clearly states CC1 - not availalbe with B2L option etc... The last year that this was not the case was in 1989 for FIREBIRDS... I can't imagine Camaro being much different... But they did give the Formula 350 T-tops in late 91 and in 1992 and nothing else, so apparently they had something in mind.
I know there are a few Firebirds with 350's & t-tops in 87 & 88, but not many. Seems to be alot more Camaros out there.
as for your P2P rpo,. I did a search and came up with nothing... P20 is something to do with hub caps. P?? seems to deal mostly with suspension, so P2P probably has soemthing to do with wheels, your center cap or suspension...
John
John
John
John
I also have a question about these.
T93: How do I tell if I have the smoked or special lights.
E5Z: What exsactly dose this delete.
Adam :-)
Colors are always two numbers and a letter or number from GM.
For example:
19Q - MOLDING COLOR (BLACK)
41U - PRIMARY COLOR, EXTERIOR, BLACK
62I - INTERIOR TRIM, LT SADDLE (I)
622 - TRIM COMBINATION, LEATHER, LT SADDLE (2)
88A - STRIPE COLOR, ACCENT,
The first 2 numbers indicate the color, for example 19 & 41 in this case are Black. I think in this case the 19 Black inticates a Plastic piece that the color is moulded into the plastic, not painted, and the 41 is the paint color. 19 is typically used for interior trim color
The U inticates paint Upper in the 41U, if there is no secondary number then the lower 41L is sometimes considered a given and not listed.
The stripe color is 88 Probably a silver color, I do not have it listed in my info.
Here is the standard designations for GM (the 3rd digit)
A= Body Accent Stripe
B= Cloth Interior Trim
C= Cloth Interior Trim
D= Cloth Interior Trim
E= Cloth Interior Trim
F= Covering Floor Mat, Color
G= Cloth Interior Trim
H= Cloth Interior Trim
I= Interior Trim
J= Cloth Interior Trim
K=
L= lower (Secondary) Paint
M=
N= Interior Trim Combination_
O=
P= Wheel Color
Q= Molding Color
R=
S=
T= T-Top Color
U= Upper (Primary) Paint
V= All Vinyl interior Trim
W= All Vinyl interior Trim
X=
Y= All Vinyl interior Trim
Z= All Vinyl interior Trim
1= Interior Trim
2= Leather with Articulating Seats
3= Leather
4= Leather
5= Leather
6= Leather
7=
8= Cloth Interior Trim
9= Seat Belt color
For example:
I= Interior Trim
K=
M=
O=
P= Wheel Color
Q= Molding Color
R=
S=
T= T-Top Color
X=
1= Interior Trim
3= Leather
4= Leather
5= Leather
6= Leather
7=
9= Seat Belt color
Linson
08-21-2015 02:12 PM
