have a big problem with rpos
Old 08-06-2005 | 08:00 PM
z28wiz's Avatar
Ok just bought my new car last week. THe rpo sticker is ripped out of the glove box. And four dealers wont give me any info with the vin they said its not possiable. IS there anyway to find out what options the car has
Old 08-06-2005 | 09:29 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Start looking for the build sheet. There could be one in a number of places like under the carpet, stuck up under the springs of one of your seats, under the rear seat, above the gas tank etc... If you don't know what a build sheet is do a search on this site, it's easier than me explaining it here.
Old 08-08-2005 | 11:03 AM
z28wiz's Avatar
as above i checked the glove box for build sheet. I looked under the seats and there was nothing. I guess my quesiton is is there more then one build sheet in a car?
Old 08-09-2005 | 06:40 AM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
yeah..they probably cant look it up unless its a 90 and above. i work at a dealership and i wanted 2 look for mine too. but mine is an 89..so i guess i gotta start lookin too. if u send me the vin ill try 2 look it up for u. maybe itll work on ours??
Old 08-09-2005 | 08:16 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
You won't find it there. The build sheet is always hidden somewhere within the car, if it's there at all.
Not under the seats either. Remove the front seats. Look under the bottom seat cushion. The build sheet is often stuck between the seat cushion and the metal springs. This is where I found mine in my '87. After this many years, it's basically impossible to remove it without ripping it to shreads.
In a '92 I owned briefly, it was in the passenger side door, stuck between the door panel and door itself.
I've never found more than one per car and sometimes none.
hectre13
12-11-2023 08:14 AM
89redeyeRoc
Car Audio
08-24-2015 07:01 AM
Regal105
08-23-2015 03:45 PM
overdriv
08-20-2015 03:52 PM
sreZ28
08-14-2015 07:48 PM
Quick Reply: have a big problem with rpos
