Tell me about my Camaro
Car: 87 Iroc Z28
Engine: 5.7l TPI
Transmission: 700/R4
I have just recently joined this message board and noticed by looking around that I have no clue what you guys are talking about. I noticed a lot of codes and very educated people just by reading the board. I just recently decided to restore my camaro. It hasn't had any major modification and is in fairly good condition. I was wanting to know if anyone could tell me a little bit about my car. It is a 1987 5.7l Tpi Camaro. The vin: 1G1FP2181HL149008. The car has power everything including windows, hatch, seats, and even the rearview mirror. The guy I bought it from said that it was optioned out. So if anyone could tell me a little about the car, I would be greatful. If you need anymore info just let me know. Thanks For Your Time
Car: 1987 Iroc
Engine: 5.7
from what you posted I can tell it's an original 350 car. You will need to decode your RPO codes which should be in the center console box.
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
The L before the last six digits means that it was made in Van Nuys...
The 87 350 Camaros came with a Borg-Warner Australian built rear axle with a ratio of 3.27 to 1, or aka a 3.27 rear end. The tranny is a 700R4 automatic with overdrive. Pretty much the same tranny as the 4th gen Camaros. 1987 was the 1st year return for the 350 (L98) in a Camaro. Many people confuse the code for the 350 and refer to it as B2L. B2L was a package that was included when the 350 was ordered. Chevrolet always denotes their engines with an "L" as the first character.
All 1987 350 built Camaros came with an RPO code of J65. That decodes the 4 wheel disk brakes. It also included K34, engine oil cooler. 1987 was also the 1st year for the Bose stereo option. If you have this option, you also have the rear locking hardcover in the rear with the speakers in it.
1987 was the first year for Leather in the Camaro. It wasn't a full leather seat, but just the face of the seats.
The 350 came only as a TPI (Tuned Port Injection). This was the top of the line injection at the time over a carburetor and TBI (Throttle Body Injection).
Post a picture of the SPID label in the center glove box and we can tell you what they all mean.
You can also check this link to see my windowsticker to compare what some of the option codes are.
http://www.users.qwest.net/~smoyer/i...dowsticker.jpg
Car: 87 Iroc Z28
Engine: 5.7l TPI
Service Parts Idenification
I went out and looked at my console. I wasn't able to get a great picture so I wrote it down. The ones in bold text I wasn't to sure about because it was a little beat up. Here we go:
1G1FP2181HL149008 1FP87
AC3 AG9 AR9 AU3 AO1 A31 A90 B18 B2L B8W B34 B35 B4Z
B48 B84 B91 B94 B97 CC1 CD4 C49 C60 DD8 DG7 DK6 D08
D34 D6M D80 D88 E5Z E7Z E9Z FE2 GW6 G80 J65 KC4 K34
K68 L98 MD8 MX0 NA5 NP5 N33 N64 N96 PB4 P20 QDZ TR9
TT4 T93 T96 UQ1 UX1 U21 U25 U26 U29 U75 U79 VAN UK3
V73 YR1 Y51 YT1 YT9 Z28 1AY 1HV 15C 15P 19C 191 199
6ZX 7ZX 8NL 81U 86A PNL
BCCC WA L8774 U8774 19C
So there it is and like I said some might be wrong so just let me know. I'm going to take it out this weekend and take a good look at it and make any updates that I can. Thank you for your help guys.
Car: 87 Iroc Z28
Engine: 5.7l TPI
AC3 ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9 ADJUSTER, SEAT, POWER, 6 WAY
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 LOCK CONTROL, SIDE DR, ELEC
A01 WINDOW, TINTED, ALL SHADED, W/S
A31 WINDOW, POWER OPERATED, SIDE
A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B18 ORNAMENTATION, INTR, DELUXE
B2L PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
B8W Not Found
B34 COVERING, FRT FLOOR MATS CARPETED INSERT
B35 COVERING, REAR, FLOOR MATS CARPETED INSERT
B4Z IROC PACKAGE
B48 TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B84 ORNAMENTATION, EXTR MLDG, B0DY SIDE
B91 ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
B94 FENDER EMBLEM, Z28
or ORNAMENTATION, EXTR EMBLEM, BODY, VAR I
B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
CD4 WIPER SYSTEM WINDSHIELD, PULSE
C49 DEFOGGER, RR WINDOW, ELECTRIC
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DD8 MIRROR I/S, R/V, LT SENSITIVE
DG7 MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DK6 CONSOLE ROOF, INTERIOR
D08 PAINT, HIGH GLOSS FINISH
D34 MIRROR, VISOR VANITY
D6M GEAR, SPEEDO DRIVEN
D80 SPOILER, RR END PNL
D88 DECAL, STRIPE, SPORT
E5Z SPEEDOMETER ADAPTER (DELETE)
E7Z Not Found
E9Z SPEEDOMETER KEY (DELETE)
FE2 SUSPENSION SYSTEM, RIDE HANDLING
GW6 AXLE REAR, 3.27 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
J65 BRAKE SYSTEM, PWR, FRT & RR DISC
KC4 COOLING SYSTEM, ENG OIL
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 GENERATOR,105 AMP
L98 5.7 LITER V8 TPI ENGINE
MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0 MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NP5 STEERING WHEEL, LEATHER WRAPPED
or LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N33 STEERING COLUMN, TILT TYPE
N64 WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
N96 WHEEL, 16 X 8, CAST ALUMINUM
PB4 LOCK CONTROL, WHEEL
P20 HUBCAPS, WHEEL, STYLED
QDZ TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9 LAMP, GROUP
TT4 HEADLAMPS, HALOGEN, 4
T93 LAMP, TAIL & STOP, SPECIAL
or TAIL & STOP LAMP, SMOKED
T96 LAMP, FOG
UQ1 RADIO PROVISIONS, FOR STEREO
UX1 RADIO, AM/FM STEREO CASSETTE EQUALIZER
U21 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 LAMP, INTR, RR COMPT, COURTESY
U26 LAMP, INTR, ENG COMPT, COURTESY
U29 LAMP, INTR I/P, COURTESY
U75 ANTENNA, POWER, RADIO
U79 SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN ASSEMBLY PLANT, VAN NUYS, CA
VK3 LICENSE PLATE, FRT MOUNTING PKG
V73 ANTENNA, FIXED
YR1 SEAT,FRT CUSTOM
Y51 Not Found
YT1 BUILD UP DR & QTR
YT9 ???
Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY Not Found
1HV Not Found
15C TRIM C0MBINATION, CLOTH, MED SLATE GRAY (C) (91)
15P WHEEL COLOR SILVER METALLIC (91)
19C TRIM COMBINATION, CLOTH, BLACK (C) (91)
191 Not Found
199 SEAT BELT COLOR, BLACK (91)
6ZX SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL COMPUTER SELECTED REAR LEFTHAND SPRING
or SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
or SPRING, COMPUTER SELECTED, REAR, LEFT HAND
81U PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
86A STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9NL SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
or COMPUTER SELECTED REAR RIGHTHAND SPRING
I found a decoder so here is what I got. Maybe someone could explain some of this to me.
B8W Not Found
B4Z IROC PACKAGE
E7Z Not Found
TR9 LAMP, GROUP
T96 LAMP, FOG
V73 ANTENNA, FIXED
YR1 SEAT,FRT CUSTOM
Y51 Not Found
YT9 ???
1AY Not Found
1HV Not Found
191 Not Found
There wil be some discrepancies as the decoder you used was for 1991. This will be noticed on color items or stripes. Do a search on this website for the RPOs you couldn't find. They have all been discussed here before.
Also, compare some items to my windowsticker listed above and you'll see other discrepancies.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
TTJ, soudns like a really nive car. I hope you restore it and keep it nice, as these cars, especailly the TPI cars are going up in value right now...
You even have T-tops which is a bit unusual for a 350 car in 1987, NOT rare mind you as there were plenty made, but it seems that most of them did not have the option.
John
John
Car: 87 Iroc Z28
Engine: 5.7l TPI
Sorry guys, I don't have any pic just yet but will try to get some soon. I more than likely will need a lot of your useful information and Im sure you guys will need as much info as I can get you to answer my questions. Ill try to get some pics by tomorrow or sunday.
Also in my attempt to restore my car, I'm in the market for some rims that match my car. The car has falcon rims with a set of falken z rated tires. The tires are a little bit more than use but the rims a in great shape. I was also wanting to know if the IROC came with special rims. Thanks again for all you help and look for the pics in the next couple of days.
Car: 87 Iroc Z28
Engine: 5.7l TPI
Hey Scott
I was wondering if your rim on your 87 say Iroc Z. Im found a set of an 86 but they don't say Iroc Z. Not sure what I need.
84z96L31vortec
08-20-2017 12:16 AM
