Heaviest Generation Camaro
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
What was the heaviest Generation Camaro ever built?
1ST
2ND
3RD
4TH
1ST
2ND
3RD
4TH
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
My '89 LO3/T-56 weighed 3,584 when it was completely stock. It has t-tops, power everything but seats, and had the 15" wheels at the time. I never weighed the (3) 2nd-gen cars I had but they felt about the same.
Engine: L98, Hemi 6.2
i kno 1st gens are the lightest (from what i heard) i think either 2nd gens or 4th gens are the heaviest..
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Originally posted by IROCZTWENTYGR8
Lightest to heaviest, believe it or not:
3rd
1st
4th
2nd
The lightest Third Gens were about 40lbs. lighter than the lightest 1st Gens.
3rd
1st
4th
2nd
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
The lightest Third Gens were about 40 pounds lighter than the lightest 1st Gens.
Reads fine to me?????
Car: 1987 Iroc
This website I was just on had all the specs
http://www.f-body.org/tech/tech.htm
It says the second gens were 3616
the third gens it says were around 3100-3400 depending on z28 or convert
the fourth gens were around 3200-3500 depending on if you got a convert or z28
Then on a seperate site it said the first gens were 2700-3100 depending on options, motors, etc..
If anybody has another site that says any of this info is wrong please let me know. Hope this post helped.
3rd
1st
4th
2nd
3rd
1st
4th
2nd
My bad.. Was up a long while before i read it.. the "40lbs." threw me until i got back on today and read it. thought it was a period in my sleep deprived haze lol
1 Post
Car: 82z28
Engine: 406
Transmission: th350
I think it goes lightest to heaviest
1st
3rd
4th
2nd
I base this off of a quote from the white book
"Nearly all deminsions were reduced, including a seven-inch shorter wheelbase, and weight was reduced by nearly 500 lbs as compared to the 1981 model. But, as the camaro has grown in weight over the years, the 1982 model was within 70lbs of the original 1967 Camaro."
1st
3rd
4th
2nd
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
my 1988 sc with an lo3 auto weighed 3201. full int, no weight reduction, all power no t tops.
my 1988 gta weighed 3515. it was optioned with ac and analoge gauges.
Administrator
1st
3rd
4th
2nd
1st
3rd
4th
2nd
According to my buildsheet, the shipping weight of my car was 3478. the front weighed in at 2064 and the rear was 1414. I have never weighed the car, though.
Administrator
For my 87 L98 IROC-Z it's 3,461lbs. for the shipping weight on my build sheet. It comes in at 2,064lbs. front and 1,397lbs. rear. Which makes sense as I don't have leather, trunk trim, locking storage cover, or cargo cover as you do. Besides those things, the car is fully loaded with the same engine, trans, axle, T-tops, body, etc. as you. (they even both came from the same state as you know)
It should still be close to that, I've only taken out some unecessary restrictive baffling around the air intake and all it has added is an all new stereo system with an amp and bass tube which are both light. Someday SFC's will add about 25lbs. to always keep it tight. (maybe full exhaust too )
1 Post
Car: 82z28
Engine: 406
Transmission: th350
shipping weight on my 82 Z28 was just 3296.
Front - 1945
Rear - 1351
That was before the interior was gutted, the A/C and emissons ripped off...and so on.
Front - 1945
Rear - 1351
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
Thomas
Exterior Parts for Sale
21
10-07-2015 05:33 PM
Thomas
10-03-2015 05:34 PM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
