How is "Zinc Weld Thru Primer"???
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I told my dad i needed duraglass to cover my welds. Well he brought me home a spray can of "zinc weld thru primer" should i use this stuff? I know nothing about it.
Car: 89 Camaro RS
Engine: 305 TBI
You use that primer in between the metel being welded together. not on the outside. So that it protects against corrosion. Then on the visible metal you would then use primer and paint.
no green
01-09-2016 09:22 PM
