info on this car if poss
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
Hi all well i have finally collected my first thirdgen camaro. The problem is i dont have a clue what it is , it wa imported to england a few years ago and the docs are a bit confusing. i found some codes on the car and i was wondering if any of the guys could shed some light on them:-
lower windscreen drivers side - 1G1AP87S8DN134293 (1 MAYBE I)
plate under the hood - D O2B 1FP87 N 1 34 293
17C 1 5 L 1 5U E
AR9 CC1
Z28 D80 PT
071124 780786
i have wrote the code as it is on the plate
The car was given to me by my dad and he told me it was a 1983 Z28 camaro 5.7 350. I now read that the 5.7 was not available that year but the reg docs do read 5.7. couldn't find the engine code as the engine has surface rust but it has a 0-1850 holley four barrel carb ( is this suitable for a automatic transmission) on top of the engine it reads 'CONTENDER' ?.
any help will be gratefully recieved
17C 1 5 L 1 5U E
AR9 CC1
Z28 D80 PT
071124 780786
1 Post
Car: 1984 Trans Am
Engine: GMPP 350 V8
According to your vin # It looks like your car was originally equipped with a 305 (5.0) LU5 Cross-Fire engine.
The cross fire unit was could have been swapped out for a single carb. Or perhaps a different m otor was installed, but when the car was new it had an LU5.
Engine: 350 L98
where about on the engine is the code i had a look but could not see it, is it tucked away,.
Car: '84 Z28
Engine: L69
Originally posted by NoItsNotForSale
In the vin 1g1ap should be 1g1fp right? F for Camaro?
Engine: 350 L98
thx david that one was confusing me as my vin seems to check out on all the databases
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Originally posted by fin170703
also did they produce the crossfire engine in 1983
The Tuned Port was a fine successor, and we all thank the trickle-down status of developments.
The higher integration of electronics makes it harder to mix and match as LS1- LT1 conversions show
Bill
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
