1LE option?
Car: 1988 GTA
Engine: 1989 5.7ltr V8
1LE option?
I have an 88 GTA with the L98. I dont have the 1LE option but I do have some of the items that came with the option including alum. drivshaft smaller aluminum spare tire and dual cats.Why does my car have these but not the option code?
Car: 4
Engine: 6
Transmission: 5
The aluminum driveshaft and dual cats are part of RPO G92. The spare tire is another option (might or might not have been part of G92 in that particular year & model, I don't know) RPO N10 IIRC.
1LE may have automatically triggered, or even included, G92. Again, I'm not sure. But however that may be, you have G92, not "part of" 1LE.
Car: 1988 GTA
Thanks for the reply but I also dont have that option code. The following codes are the only ones that are on the window sticker.
B20
C67
U52
Y84
81U
B20
C67
U52
Y84
81U
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
CHeck your RPO sheet in the center console. Or get a free dealer invoice.
As for the Dual cats that was started in 1989, and was only on the Formula from the factory on the firebird line. (according to a media kit I have)
The Dual cats were not availble even on the 1LE package in 1988. Chances are someone had converted your car. Which is more than likely.
You can purchase the Alum driveshaft from SUmmit for example.
John
John
Engine: 4++,350 & 305 CIs
If you have the spoked spare its not a 89 and up 1LE spare.. those are painted black and look very close to a regular spare but its 25 lbs lighter
I have both.. I need to post some pics of the differences
TOny,
Quickie question fer ya...
Does your car have the dual cats option.. I know its no longer stock, but did it come from the factory with Dual cats?
John
John
Yes it had the N10 option (still have it in the Garage along with my orginal cat back ) , shes got all the performance stuff but 1LE
I think that is the only way you could get a Formula 350 in 1989... With the Dual Cats & all... Just checking.
John
John
Is RPO G92 different for the Pontiacs?
Thanks,
-Andrew
Still not sure about G92 for Pontiacs
Sorry guys, but I'm still lost in regards to the RPO G92.
On a Pontiac, what did G92 do to the car - were any of the 1LE components added?, or like a Z28 - did G92 without A/C trigger the 1LE build? After reading some of the first posts in this thread, it sounds as if components like the aluminum drive shaft could be on a car that only had RPO G92? (I do know that there are exceptions to all the rules but???)
After reading a pile of books, the way I understand G92 is that this option gaved the buyer a performanced axle ratio, and was only orderable with the LB9 and 5 speed or B2L with auto trans. The car was outfitted with the dual cat exhaust system, (RPO N10) 4 wheel discs (RPO J65) and engine oil cooler (RPO KC4) - no 1LE parts were added unless A/C was deleted. No alum drive shaft, dual piston brakes, gas tank, light weight spare etc..
Can some one fill me in please?
-Andrew
-Andrew
Car: 1987 Black IROC-Z (SOLD)
Re: Still not sure about G92 for Pontiacs
-Andrew
-Andrew
Administrator
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Please use and read our Tech Data on the main page.
Originally posted by 1991z281le
We have 3 1991 Z28 1LEs with the spoked aluminum spare and 2 with the solid black aluminum spare. As we've seen, the spoked spare was phased out sometime during mid model year 1991 as all the spoked spare cars were build in the first half of 1991 production.
This will throw a wrench in both of our thoughts on this ..
we have 2 89 TTAs in the shop and both have the painted aluminum spare... ?!?!?!?!
I haven't ever checked to see if the spoked wheel really fits over the front 1LE brakes.. I might just have to try it some time...
I wonder if they had 2 suppliers and just threw in whatever they had in the bin???
Originally posted by 84 1LE
GM would delete the Bigger front brakes,but leave the Rr disc in place.Since they are part of the G92 package.I guess GM figured if you wanted A/C & or foglamps.You werent going racing.Since the A/C system adds weight & with the foglamps reduces airflow the radiator.Two things you wouldnt want if your running hard.Most of the remaing 1LE package was also left on the car(oilcooler,alum dr.shaft,higher durameter rubber bushings,dual cats,baffled tanks became standard in 1990 ive read/heard.Almost all other options were available though with 1LE.None of this of course applies to the B4C package. [/B]
- remaing 1LE package was also left on the car(oilcooler,alum dr.shaft,higher durameter rubber bushings,dual cats,baffled tanks became standard in 1990
It may have happened in the odd/exceptional case- but this was not the regular case - i have seen many a 91 - 92 Z28 with G92 and 4 wheel discs but no aluminum drive shaft baffled tank etc...
I keep hearing things like what has been quoted, and want to know where this info is comming from - Can you pass this on?
-Andrew
I Know information can sometimes be incorrect.Ive read many articles on this,but the last book i remember reading about this was the camaro "white book".At the very least The BIG front brakes were deleted from the 1LE package if you ordered A/C &/or foglamps.Perhaps leaving most all other 1LE options intact?
I can see your point -
I have methodically read the "white book" - personally, I think that as a general reference it's a great source, but after this - ... In some cases the info presented is a bit vague, inaccurate etc...
In my opinion, I can't see why GM would leave any of the 1LE components on the car if A/C or fogs were added to a G92 optioned car. Here are my reasons:
1. G92 had to be ordered first - 1LE came next - so the extra parts would not likely be installed, and, only after A/C was deleted would the build switch to 1LE specs.
2. The 1LE parts cost more $$ than the standard Z parts - (mistakes could have been made, special orders were possible, etc, etc.. but - ) so GM wouldn't be adding these upgrades, I don't even think they would substitute them if the regular parts were out, or delayed.
Just my 2cents....
-Andrew
Just my 2cents....
-Andrew
If I remember right.. didn't the Z have the 1LE option on the order form..
The birds where harder to order, you had to have the G92 C40-1?? (AC delet) R6P and something else I have a sheet at home with the correct way to order it...
I think there is a person on the boards who claims to have the 1LE RPO, he got A/C and power everything. It was on a 91 or 92 Formula if I remember right, I belive he even posted his RPO sheet.
So this leaves me with a delemma, if you delete everything off the car, and then put the G92, and then the 1LE options pop up, why could you not start adding options back on top of it. I wonder if it would work that way.
I dont know, just trying to remember.
and BTW, the Camaro White book may be a great resource, unfortunately I think it may be worthless, because of the innacruacies, how could I trust it? I wish there was an accurate version for firebirds.
John
John
... and BTW, the Camaro White book may be a great resource, unfortunately I think it may be worthless, because of the innacruacies, how could I trust it? I wish there was an accurate version for firebirds.
John
John
On the topic of reading material - Peter Sessler put together a 'not bad book' called Firebird Red Book Motorbooks International 1992. It covers all F-body ponchos up to '91 - missing a lot of info out of date now - I can't seem to remeber if a new volume has been printed, but like the Camaro white book it's a start. Even the Standard Catalouge of Firebird and Camaro are missing a lot of info ... nice pictures though
-Andrew
I have the road test of that 1LE formula with A/C kinda neet
Car: 1983 Trans Am (not running)
Can somebody tell me what size of spare came on the 1LE equipped cars? I ask because I plan to upgrade my front brakes to the Baer Sport kit (looks like a clone of the 1LE set up with a 12" rotor and two piston pbr caliper. My car came from the factory with a 125 70 15 spare (don't know the off set of the wheel)- anychance this would fit or will I have to search for an oddball spare? I plan to put a lot of highway miles on my car when it's finished and I'll need a spare.
Thanks,
Trevor
Thanks,
Trevor
gixxer92
05-18-2017 11:20 AM
