Found My Build Sheet
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Take a look at this.. its mostly readable
Rabbitt
Rabbitt
Car: 1987 Iroc-Z
Engine: 355
Driver's side rear seat cushin for me, to be exact.. when i found it, i was fricken ecstatic! lol
Car: 1987 Iroc-Z
Engine: 355
729 -SEAT BELT COLOR, DK CARMINE (9) (91)
A01 -WINDOW, TINTED, ALL SHADED, W/S
A31 - WINDOW, POWER OPERATED, ALL DOORS
A90 - LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
AM9 - SEAT, RR, SPLIT, BACK, FLDG
AR9 - SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 - LOCK CONTROL, SIDE DR, ELEC
B18 - ORNAMENTATION, INTR, DELUX
B34 - COVERING, FRONT, FLOOR MATS, CARPETED INSERT
B84 - ORNAMENTATION, EXTR MLDG, BODY SIDE
B94 - FENDER EMBLEM, Z28
B94 - ORNAMENTATION, EXTR EMBLEM, BODY, VAR 1
B97 - ORNAMENTATION, EXTR MLDG, LOWER ACCENT
BS1 - INSULATION, ACOUSTICAL PKG
C60 - HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C94 - LAMP, DOME, DELAYED
CC1 - ROOF HATCH, REMOVABLE PANELS, GLASS
CD4 - WIPER SYSTEM WINDSHIELD, PULSE
D08 - PAINT, HIGH GLOSS FINISH
D34 - MIRROR, VISOR VANITY
D35 - MIRROR, OUTSIDE REAR VIEW
D80 - SPOILER, RR END PNL
D88 - DECAL, STRIPE, SPORT
FE2 - SUSPENSION SYSTEM, RIDE HANDLING
GU2 - AXLE REAR, 2.73 RATIO
J42 - BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, ALUMINUM
J50 - BRAKE SYSTEM, POWER
K60 - GENERATOR, 100 AMP
LG4 - ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MD8 - TRANSMISSION, AUTO 4 SPD, THM 700 R4
15P - WHEEL COLOR SILVER METALLIC (91)
72C - TRIM COMBINATION, CLOTH, DK CARMINE (C)
81U - PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
86A - STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
B4Z - IROC PACKAGE
N33 - STEERING COLUMN, TILT TYPE
N65 - WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N96 - WHEEL, 16 X 8, CAST ALUMINUM
NA5 - EMISSION SYSTEM, FEDERAL, TIER O
NP5 - STEERING WHEEL, LEATHER WRAPPED
NP5 - LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
P20 - HUBCAPS, WHEEL, STYLED
PB4 - LOCK CONTROL, WHEEL
QDZ - TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
T93 - LAMP, TAIL & STOP, SPECIAL
T93 - TAIL & STOP LAMP, SMOKED
T96 - FOG LAMPS - FRONT
U21 - CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U79 - SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
UA1 - BATTERY, HEAVY DUTY
UM6 - RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UQ1 - RADIO PROVISIONS, FOR STEREO
V73 - ANTENNA, FIXED
V73 - VEHICLE STATEMENT, USA/CANADA
VK3 - LICENSE PLATE, FRT MOUNTING PKG
YR1 - SEAT, FRT CUSTOM
YS1 - SEAT, RR CUST
YT1 - BUILD UP DR & QTR
Z28 - MERCHANDISED PKG, SPECIAL PERFORMANCE
Woo-hoo! All my rpo's decoded
Rabbitt
B4Z - IROC PACKAGE
YS1 - SEAT, RR CUST
Rabbitt
Engine: 4++,350 & 305 CIs
I found a broadcast sheet thing during the 2nd repaint (my first repaint)..... it was behind the front bumper cover and kinda messed up but its mostly readable
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
The factory just shoved the build sheets into random places? I've been through my entire car and found many extra parts but no buildsheet.
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I found my 92 Z28 convertible's build sheet between the passenger door frame and the door panel. Weird hun?
Car: 91 formula
Transmission: t5
wow that is weird, i live like 2 minutes from george luddy chevrolet in holden, ma
kinda freaky to know that your car moved that far away when it was so close to me to begin its life
I have only specifically looked in 3 cars (out of I don't know how many f-bodies i've owned) for the build sheet and all 3 times they were under the drivers seat. the cars were and 82 an 83 and of course my 84. one thing I noticed on all the buils sheets is that they were all built in Van Nuys so maybe from that plant they were all put under the drivers seat maybe?? def a great place to look if you want to try and find yours BUT be very carefull removing it b/c under the seat is a very destructive place to remove it from. unbolt the seat and don't try to just simply pull it out b/c it won't work. the build sheats are usually pretty fragile so handle them with care and get them laminated asap to prevent any further damage.
Car: 1987 Iroc-Z
Engine: 355
hehe, getting there... I have the gears (3.73 and made by Motive), the posi (Eaton), the installation kit (Timkin) and the axles (MOSER hardened). I just need the outter axle bearings and someone to put the stuff in (the guy who is gonna do it is busy for awhile)....soooo... i'll have it done soon.. lol
1 Post
Car: 92 Z28 heritage
Engine: 5.0 TPI
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Found My Build Sheet
Sweet find, I want to find mine as well and keep it with my window sticker. I'm not gonig to tear the car apart lookng for it, but I will check a few places.
Holy 7yrs ago!!!!
Car: 1991 Camaro RS
Engine: LH0 3.1 MPI V6
Transmission: 5-Speed Manual
Rabbit,
I was hoping that car was sold to Swenson & Son. That would have been way cool for you!!
