Searching for GM OEM paint chip samples
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
Hello,
I'm looking for GM OEM paint samples off the "NET".I have an 87 Firebird and I want to see what other exterior paint options were available for that particular year.More specifically for solid exterior colors.
I had the Dupont sample book,but misplaced it when I moved.So if anyone out there can help I would appreciate it alot.Thanks to a member in this section I was able to get the correct code for my car which was Med Gray Met # 84...THANKS(you know who you are).
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
check at www.autolit.com
I have bought tons of stuff off this guy. His stuff is great. Nearly everything I have bought off him has been BRAND NEW condition. I am sure he would have, or could come up with the '87 GM paint chip brouchure....he had the one I needed!!!
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
How do you fit your car in that garage?
Try Auto Color Library while your waiting for actual samples.
http://www.autocolorlibrary.com/scri...gm=aclgate.bbx
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Factory Auto manuals has alot of that stuff... www.factoryautomanuals.com Also you should be able to go to an auto parts store that sells paint, and look through their chip book...
Here is the chip book from Pontiac in 1987 if it helps...
For some reason I am having trouble uploading a pic...
Street Lethal
04-30-2019 12:14 PM
NBrehm
08-25-2015 11:49 PM
NBrehm
08-05-2015 07:57 PM
