The History Channels "Full Throttle" show does 3rd gens?!?!
#102
Engine: 4++,350 & 305 CIs
Originally posted by Aron9000
I saw the show and kept thinking of ways to make it better. The history portion was good(could have done with less Mustang footage though) and shouldn't be changed.
The times they got out of the IROC were pretty good when all the factors discussed earlier are considered.
Now ways to make the show better:
1. Fire the Turbo twins and get Dean Skuzza and Cameron Evans. It doesn't have to be those two, but race car drivers or mechanics would make excellent hosts.
2. Don't hire the first four clowns you get off the street. At least hire people with higher skill levels than being the lube guy at Jiffy Lube. A great way to get contestents for the show would be to surf the message boards(like Thirdgen.org) and pick members who are very knowelgable, have a good rap with the board, and have built their own cars.
3. Maybe give the guys three or four days to turn the wrenches on the cars. If you are using experienced guys, they could so some serious mods with that much time on their hands(heads, cam, intake, headers, nitrous, custom chips, swap a rear end, etc.) Also make sure that the cars they are modding are in top mechanical shape and will be able to handle the additonal power without frying rear ends, trannys, throwing rods, main bearings, etc.
4. Force all contestents to familarize themselves with drag racing by practicing before the show. This won't be an issue if they put experienced people on the show.
5. The most important point: Give both teams 10 or 15 trial runs down the strip. Let each team decide who will drive(if they are smart, the same guy will drive). This will hopefully allow them to become familair with the cars and work out any bugs. Then give them 1 race to decide who will win both cars.
Just want I wanted to say but I don't like to type
#103
1 Post
Car: 1992 B4C 1LE
That would avoid things like big-block trannys for small blocks (like in the mustang episode), and larger aluminum radiators in blower cars were a stocker can barely fit on 300 hp cars when the stockers can support close to 500 hp (this camaro episode).
If they had one specialist in the field he could also help people understand wwhich mods will do the most, and atleast offer a bit of assembly/disassembly advice to avoid wasted production time.
The silliest part is that a basic internet search would yield "specialty" groups of enthusiasts for specific cars that could advise the producers of likely candidates for show advisors. Here on this site we could make suggestions of likely people just from this site that could make better advisors than anyone they could have found regarding third gens.
The mustang enthusiast sites could have yielded a decent advisor for the mustang episode.
The 240-260-300Z sites could have yielded a better advisor for that show.
As far as Dean and Cam, I would have to say that I would have been interested in hearing their personal opinions and experiences with the vehicles at hand.
#104
#106
Transmission: TH200C....700R4
Quote from marc85z28,"Shouldnt the moderators at least have to pass a basic car knowledge test!"
Im sure Okfoz has passed many test,maybe more than you.He has plenty of knowledge that has helped me and other members on this board with.Ive worked with electritians that have 40 years exp and even they get stumped ,so dont bash because he asked a question.
#107
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
#108
Car: / 89 IROC /
Did they say they were both 350 cars? I saw the red one had T-tops, I though you could only get the 305 with the T-tops, at least that is what the deal was in 89 when I bought mine.
#109
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I have the show edited with no commercials ready to post on tgo if someone wants to host it for me .. and for all of us actually
its 297 MB (311,811,290 bytes)
I/m me at sean001134 if u can host it
#110
I'm sure the History Channel has a statement regarding replaying their copyrighted shows for public display is not allowed without prior permission. Let's not get TGO into legal issues over a show that wasn't that great to begin with.
Please, no more asking for copies of this show or requests to host it on a site for others to see. If this is done thru PMs, then TGO can not be held responsible, but no posts regarding a link to the pirated show are allowed on TGO. If any are found, the post will be deleted.
#111
Note they mentioned the fuel system, needed 60 psi at higher capacity, then they dropped it. I'd guess someone behind the scenes chiselled the body and put in a new HV pump.
Also note the blower is overdriven about 2.5:1 by the engine pulley, so 4000 rpm at the motor is 10,000 rpm at the blower.
Note the young guys got the best time with shifter in "auto" and not hand shifting. There's a lesson in that.
Whoever designed the blower mounting needs to install one on an actual car, that upper hose deal is plain wrong. Should be no interference in an expensive deal like that.
Nice the see the best looking cars ever built get some TV time!!!
#112
1 Post
Car: 1992 B4C 1LE
no, the guy says they have to INSTALL a new in-line pump because odf the 60 psi capacity and then the computerized graphic shows the pump setup
#115
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Personally, if they don't feel the need to reference knowledgable sites like this in particular to experienced car owners, why would they look after the fact for copyright infringements?
Content removed by moderator
#116
1 Post
Car: 1992 B4C 1LE
A&E/History Channel order line for a copy of this episode:
1-800-708-1776
VHS only!!!
item # AH44234
they said they are slowly switching over to DVD, everyone needs to call that number, press 1 to order, and then tell them they need to make this video in DVD.
1-800-708-1776
VHS only!!!
item # AH44234
#117
They do have people that checks for that. Copyright infringement is a major deal. Taking the time to verify the accuracy of their content is not.
Reopening this thread due to popular demand. Any requests for copies of this show will result in the user being put on probabtion and the thread closed again.
#118
Car: 1989 iroc
Axle/Gears: 2.77
all and all not a bad show. I was just happy to see iroc's on tv. I could of done without alot of the mustang footage on the history of the pony car thou.
#119
Car: '89 RS
Engine: 383 in progress
Transmission: TH 700-R4
Does anyone know if there will be a re-run for this show?? I saw it the first time and loved it but I wanna see it again. I missed about the first 10 minutes
#120
1988 Iroc-Z Camaro.
Airs on Saturday, January 22 at 5:00pm ET
Tonight at 7 there is a Jeep show, might be pretty good on the early army jeeps.
#121
Car: 1990 RS coupe
Engine: TBI 305.
One random comment about the ET's they are running
Keep in mind most of the guys they have on the show are inexperienced in drag racing
and who really wants somebody with sub par driving skills barrelling down a track at over a hundred miles an hour?
#122
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Originally posted by B4Ctom1
now they are lying for them about the oil leak
#123
1 Post
Car: 1992 B4C 1LE
I have stacked filter gaskets before by having the old one stick to the block, but you know as well as I do that they got in a big hurry and screwed up the oil feed/return lines somehow lines. probably left one off.
#125
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
innexperience and a state of mind derived from people who only drive stick and never wanna drive anything else. People in a pontiac forum i used to frequent when i had one used to try manually shifting their auto all the time, they always came back with results showing less performance than just sticking it into drive. You'd figure some old school guys would have learned that but they dont really frequent the internet too often. I have an uncle who builds hot rod cars that still believes that once you use synthetic you can't use anything else. It's a lack of communication with other members of a automotive community that allows that type of thinking.
I doubt those kids will keep the camaros, they wouldn't know what to do with them or how to drive them. Much more likely is that they'll sell them or part them out and use the money to buy their skyline conversion body kits and 6000watt speakers with magnets big enough to make them sterile from 20ft away.
#126
1 Post
Car: 1992 B4C 1LE
I always manually shift my 700 car but I watch my RPM closely anything too high and you are wasting your time.
The reason I manually shifted is because a huge point of failure in a 700 is the forward input sprag. Even the special 29 element sprags will fold up and go home when faced with too many WOT shifts. Especially with sticky tires and any kind of decent horsepower.
Sure there were some diode input sprags around for a while but metal fatigue from improper metalurgy caused most of those to fail (it was hit and miss).
The difference is manually shifting you get the added support of the little overunning clutches helping the input sprag in manual 1, 2, and 3. They have to release in 4th or the tranny would bind.
Also in manual first when you launch you have the low reverse clutches helping to hold the low roller from slipping and being damaged.
The way I understand it is that 4L60E's (in 4th gens) only have some of these benefits.
BTW if you are interested, from a guy that builds trannys I have read these guys site, they not only build 700's the way I used to , they have incorporated every new product into their trannys that I would have if I were still building.
I may actually buy one from them just because I can't get all of the parts anymore, and I don't know if I want to switch the B4C to a T-56. I just thought you might be interested to know.
http://www.transmissioncenter.net/700r4.htm
anyways regardless of all of this, Im betting those fool throttle dudes didn't know any of this. I just wanted to make sure the rest of you don't go spouting nonsense that manually shifting a 700R4 is bad.
It is bad because you will likely go too high in RPM and wo't concentrate on everything else, so you will lose.
It isn't bad if you want your tranny to live longer.
#127
Actually in my experience by simply leaving it in drive the transmission shifts faster. If I leave it in drive there is no lag between gears.
But I think my car is screwy...
John
John
#128
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the speed of the gear changes are identical.
putting it in 1st jacks up the pressure some, so on a worn trans, it helps.
also, since the shiftpoints arnt ideal, you can gain time by manually shifting a dead stock car.
the thing is, you need to go down the track 15-30 times, each time shifting a little diffrent until you figure out what the car wants.
they only got 3 runs, and each one counted.
personally, if i was doing that, i would still manually shift it... athough i already have a very good idea of when i needed to shift it.
#129
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
I agree on the manual shifting points. They only had 3 trys, however, us 3rd gen owners have the opertunity to see where our cars can be shifted for best times. There are threads on here showing time slips with manual and auto shifting. Def decent differences, especially if you have a nice aftermarket shifter, shift light, and better rpm readout. I know many that manual shift, which is why they spend so much attention to the shifter.
As for the show...
I liked it because i got to see third gens. 2 beautiful, well kept third gens just as old as mine. Theres no where else i would get to see those cars on tv and actually have a show dedicated to them. However, they needed to fix a few things which others mentioned above already somewhat:
-cut out the IROC racing footage (circling the track lasted for 5 min of the show)
-i think the supercharger 7000rpm reference really was geared towards the car's rpm. None of these guys were knowledgable on these cars and being import tuners they would know any better (more than likely). The system does however work with a 2.5:1 pulley that would make the charger spin faster than actual engine rpm. but think about that mathematically at 7000rpm
-get rid of these guys, they are a joke. Some of you are on here defending them, but i think they should just restructure the show. Put some knowledgable people on there that can tell us about cams, heads, and tuning. Im so tired of trying to watch full throttle, pimp my ride (ha...just maybe), and overhaul in hopes of actually seeing specs on these buildups to help me learn more. Instead they have to gloss over everything, making the show appeal to a general audience. Very unfortunate.
-I dont feel a better connection to the show because these guys are supposed to be average joes like.
-Give the guys more time and actually overhaul the entire car-suspension, chassis, tranny, engine, maybe even interior.
-guys that own these cars are watching these shows and want to see what is being done to their cars. When you try to make a gameshow out of these buildups, it becomes a joke and quite worthless as far as being informative.
ill go ahead and stop, sorry the long post. I give the show a B only because it showcased such wonderful cars. If only speed vision would do a nice 3rd gen buildup now.
As for the show...
#130
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Besides, even if one stuck on the filter mount, would you still get a leak like that? Never had a gasket stay behind on me (I agree with them screwing up a line and not going to argue otherwise... I'm just curious).
#131
Car: 91 Camaro Vert
Originally posted by Goumba T
Yeah, and I really don't think of those gaskets as O-rings. However so much has been said of these guys that I won't go any further.
actually, yes you would
if you change the filter adn the old rubber seal stays on, theres two things that can happen:
1. it leaks HORRRIBLY.. like on the show.
2. the pressure skyrockets.. last time that happened, the filter actually buldged out.
its just a simple check to make sure the old one came off, but alot of people dont do it... i always check now, but only because ive made that mistake in the past.
#132
Car: 88 Firebird
Engine: 350 LO5 TBI
the shop i work for made that mistake about 2 or 3 years ago on a car (double gaskets) and the car drove about 5 miles and tanked. It had built up pressure and the engine blew. the way it looked though wasnt anything like it did in the show. their problem seemed fuel line related and not just filter.
#133
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Heh, thanks. Hopefully that'll scare me into remembering every time. Sometimes I look, most of the time I don't, guess I rely on my quality PF25 to come out in one piece too often.
Hey, I actually learned something from this show.
#136
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
Was it just me or did anyone else wanna see the guy who was driving the twin turbo car take that white IROC for a run?
Really though, a new radiator instead of headers?
#137
Originally posted by scottmoyer
Damn man have a memory
#138
Engine: L98, Hemi 6.2
Originally posted by RebornCreed
The part where the english ***** is smashing him in the red firebird trying to get memphis to steal cars for him.
#140
My post was trying to figure out how the scene in "Gone in 60 Seconds" has anything at all to do with this thread. Maybe instead of telling us to have a memory, you should pay attention to the content of the thread.
The last thing we want now is another, "What movies or TV programs have 3rd gens been in?" We've been over that before!
#141
:werd: theres to many threads about it... There even one on the Detailing Forum
