RPO codes
RPO codes
Heres my RPO codes i dont know why some dont work
AC3 : ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9 : ADJUSTER, SEAT, POWER, 6 WAY
AU3 : LOCK CONTROL, SIDE DR, ELEC
A01 : WINDOW, TINTED, ALL SHADED, W/S
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B18 : ORNAMENTATION, INTR, DELUX
B48 : TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B9K : ORNAMENTATION, B/S MLDG, REAPPLY TO RR DOORS ONLY
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
Unable to locate code DO3 in our database!
D27 : COVER, RR COMPT, TRUNK STOW
D34 : MIRROR, VISOR VANITY
D35 : MIRROR, OUTSIDE REAR VIEW
D80 : SPOILER, RR END PNL
D88 : DECAL, STRIPE, SPORT
Unable to locate code ES7 in our database!
E6E : SLEEVE, SPEEDOMETER GEAR
E9Z : SPEEDOMETER KEY (DELETE)
GT4 : AXLE REAR, 3.73 RATIO
J50 : BRAKE SYSTEM, POWER
K19 : REACTOR SYSTEM, AIR INJECTION
K22 : GENERATOR, 94 AMP
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
L69 : ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO
MK6 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D NB2 : EMISSION SYSTEM , CALIFORNIA , TIER O
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
N33 : STEERING COLUMN, TILT TYPE
N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
T93 : LAMP, TAIL & STOP, SPECIAL
UA1 : BATTERY, HEAVY DUTY
Unable to locate code VE8 in our database!
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
Unable to locate code UV7 in our database!
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U29 : LAMP, INTR I/P, COURTESY
Unable to locate code V75 in our database!
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VJ9 : LABEL, EMISSION, COMPLIANCE, CALIFORNIA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
Unable to locate code YA7 in our database!
Unable to locate code YE4 in our database!
Unable to locate code YFS in our database!
YR1 : SEAT,FRT CUSTOM
YT1 : BUILD UP DR & QTR
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
Unable to locate code YO6 in our database!
Unable to locate code Z2R in our database!
1AZ : Order Modification, Orders Sold (or: CUSTOMER ORDERED VEHICLE)
16P : WHEEL COLOR, BRT WHITE (91)
Unable to locate code 17C in our database!
Unable to locate code 171 in our database!
179 : SEAT BELT, COLOR CHARCOAL (91)
19L : SECONDARY COLOR, EXTERIOR, LAMP BLACK (91)
19U : PRIMARY COLOR, EXTERIOR, LAMP BLACK (91)
Unable to locate code BZX in our database!
7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
74A : STRIPE COLOR, ACCENT, TWO TONE, BLACK/RED (91)
8NN : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
9NN : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Nvm i found some of them but some just wont work
D03 : PAINT, PROCESS, WATER BASE
UU7 : RADIO, AM/FM STEREO, CASS, CLOCK ETR
UU75 : ANTENNA, POWER, RADIO
79 : SPEAKER SYSTEM, 4, DUAL FRT OAX, DUAL EXT RGE PKG
Y06 : RING GEAR, 9.50 IN., SAGINAW, (S.P 0.)
Z21 : MOOEL CONVERSION 'GT- BERETTA
17L : SECONDARY COLOR, EXTERIOR, LT SLATE MET (91) 179 : SEAT BELT, COLOR CHARCOAL (91)
6ZX : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
