how much is this worth
Old 06-06-2004 | 12:58 AM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
didnt know where to put this so here it goes.
I have a car I might want to sell, but i want to know what to tell people the price is.
85 Camaro Z28 350 Carb engine.....Paint is primer but could use a re primer in some spots.....No louvers on hood.....NO RUST.....not in running condition.....all ready but wont start, think its starter problem....New parts, most never ran but installed on car. car doesnt run do to carb fire. Removed Radio.
Removed Emissions Equipment....Removed A/C....Newly Painted Engine And pullys....car originally had 305 tpi....original tranny and rear in car, Red cloth interior is good condition...all gauges work exept fuel and that happens to alot of camaros....all emblems are there. everything, car just needs to start and paint....stock wheels with brand new futura tires....everything is properly installed....just want to get rid of the project and get a new car....engine ran strong before small carb fire...no posi, open diff...stock 323 gears...t tops...119000 miles on body and tranny and bout 45000 on engine....power steering and power brakes with discs in front and drums on back...solid car, can be an easy project if u dont want to go full resto like alot of projects are....no dents or dings....dual crome exhaust tips power windows and locks and power hatch....all interior lights work...come with car cover.
Mods that have been run on Car.
Engine
Electric Fuel pump
New tires
Edelbrock Cam
new alternator
headers
Ravin Muffler
Holley street dominator intake manifold
Energy suspension bushings
carquest shocks
new starter
new flywheel
summit air cleaner
proform valve covers
Mods that are on the car but never ran before.
Off road y pipe
Cutout
K&N filter
Holley 600cfm vac secondary
equuis gauges
radiator
tranny cooler
mallory distributor
plug wires
spark plugs
flex fan
B&M deep tranny pan
fan spacer
battery
summit chrome radiator overflow tank
new rear tranny seal
Oil and tranny oil
Engine oil dipstick
Intake gaskets
Exhaust gaskets
Summit fuel pressure gauge that hooks up to carb
Tranny filter
whole engine wiring harness
pcv and oil cap grommets
all new hoses
I repeat all these parts are BRAND NEW and never used exept wiring harness and i got that from house of camaro
I will throw in the old carb needs rebuild kit, stock y pipe, cat converter, b&m shift kit, extra engine oil and tranny oil set of sunpro gauges, these things are not installed on car
Car is in houston.....what do you guys think i should offer it for? whats it worth? Pics are in sig
Old 06-06-2004 | 03:07 AM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
$2000-2500??????????
Old 06-06-2004 | 08:00 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Sell it??? You will be lucky if you don't have to pay to have towed away to the Boneyard.
Old 06-06-2004 | 01:44 PM
pecha's Avatar
Car: 98 T/A
Engine: ls1
IMO you'd be better off finishing it or at least having it run and then selling it
SRKLEGIN
Interior Parts Wanted
10-12-2015 07:28 AM
skinny z
10-05-2015 06:23 PM
bjpotter
10-04-2015 07:48 PM
gord327
10-03-2015 01:25 PM
6998poncho
09-25-2015 02:56 PM
Quick Reply: how much is this worth
