factoy paint codes not matching year?
Car: 84Z/ 87 S-10
Engine: 355/350
Transmission: th-350/700-r4
i have an 89 camaor rs lo3 i was doing the vin decoder and rpo decoding on it today and the vin shows its an 1989 and the rpo paint code (wa l9536) shows that fo a 1990 camaro, is this some kind of rarety? just wondering info would be greatly appreciated
I frequent the camarosource.ca website for information, but like all resources, it is not perfect. There is some misinformation on that site like there is on this site and probably every other site out there.
I will give him credit though. He tried building that site with accurate info from the manufacturer and from those that know. Unfortunately, documentation from GM isn't always accurate either which gives you a poor starting off point.
Originally posted by Intensity_Z
camarosource.ca supposedly the biggest camaro fact site on the web, they said that it was 90' medium grey metallic
camarosource.ca has a lot of good info, though it uses the same RPO decoder info from this site, mistakes and all
1 Post
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Originally posted by 82RECAROTA
87/WA 9536 is refered to as both Gunmetal or Medium Grey Metallic by GM, depending on what medium you look at. There is also a 87/9243 refered to with the same names, which is a lighter shade. One reason why you should always use the "WA" number when matching your paint rather than the name.
We don't use Thirdgen.org's RPO Decoder. I personally wrote the RPO Decoder as well as all the other Decoders (VIN Decoder, Engine Decoder, etc) on the site.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I think all it means is that the name shown was the name used for the color in 1990. My car's color decodes as "Astral Silver", but in 1984 it was called "Silver Sand".
kah992
08-19-2015 02:55 PM
